Check Engine Light on after filled up with gas? - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 06-24-2005, 01:03 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
RE: Check Engine Light on after filled up with gas?
Its in the owners manual, about the cap!
Peter Guenther is offline
post #12 of 12 (permalink) Old 06-26-2005, 08:50 AM
mdvijay's Avatar
Date registered: Apr 2005
Vehicle: 03SL55AMG,2008 F430spider
there may be a couple of problems.
i agree with the gas cap but you should not have hesistation during accelertion unless you have water in gas i had both problems with my cars.regarding gas cap ,open and recap properly.if the check engine lite is due to that it will go away in 15-20 cycles of turn on and off of the car. regarding h2o in gas you can add any dry gas made for fuel injections.but sometimes slight debris in gas can partially clog fuel injectors.i had that problem too my mb service manager recommends BK44 fuel additive to the fuel tank might help check out
and finally if you keep driving if it is a minor problem check engine lite will eventually go away after driving for a while
good luck
mdvijay is offline
