Originally Posted by aa1 Is this for petrol engines only or are diesel engines included? |
According to the original poster:
It's campaign number 2005020003.
The vehicles included are in the model ears with 1998 through 2001.
Models are:
163, 202, 208, and 210 with the 112 engine.
129, 163, 202, 208, 210, 215, 220 with the 113 engine.
Also included is the 2001 model year 170 with the 112 engine.
Don't go crazy, folks, it was a supplier problem and just because your car fits that model, engine and year does NOT mean you have a defective HB. You can check it yourself for peace of mind -- I did.
The HB is located immediately behind the large pulley at the bottom-front-middle of your engine. The part number is stamped on the outer arc of the HB, so if the crank is in the proper position it's VERY easy to see. You may have to start and stop your engine several times to get it to rotate to the correct position, obviously don't be looking around under there while the engine is running.
Once you locate the number see if it is one of the two below, if not, breathe a sigh of relief.
The only two part numbers affected are:
A112.035.00.00
and
A112.035.06.00
