what does this sign mean? - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 04-19-2005, 05:06 AM
Date registered: Jan 2005
RE: what does this sign mean?
I would have thought that anyone who went to school would have known that.....[:D]
mercmad is offline
post #12 of 15 (permalink) Old 04-19-2005, 09:08 AM Thread Starter
Vehicle: 1987 Mercedes 300e
Send a message via AIM to lnkprksoldier
hmm ok, well the right brake light was out and i went to go replace the left so it would be an even replacement . and when i get there..the brake bulb is loose like where it goes in.. in its socket.. so i put a new one in and it doesn't lock in place.... it stays loose and moves around. it made contact a while but then i checked to see if it stuck and it was still loose. i checked the brake by the help of my mom and light ddn't turn on... ideas????
lnkprksoldier is offline
post #13 of 15 (permalink) Old 04-20-2005, 08:00 PM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC 38,800 mi. 1987 560SEC Now 145K mi. (Spring 2017)
Quoted: 164 Post(s)
Sounds as if the tail lamp assembly needs replacement as that socket, from what you say, appears to be bad/gonzo.
MBL
MBL87560SEC is offline
post #14 of 15 (permalink) Old 04-20-2005, 09:04 PM Thread Starter
well the first one that i talked about was the passenger side one.. the one with the loose bulb... i think i know why... is the drivers side one
post #15 of 15 (permalink) Old 04-21-2005, 05:16 AM
hyprr1's Avatar
Vehicle: 2002 CL55 AMG, 1993 190E 2.3L
Quoted: 22 Post(s)
Send a message via Yahoo to hyprr1
Take the whole bulb assembly piece out of the car!There is a plug you have to unplug at the bottom of the bulb tray! When you have this out, you can carefully take apart the metal bracket and slowly bend all the contacts upwards a little(try not to break the plastic piece)...If done carefully, your bulbs will stay snug in place!!
Good luck,
Spiros
hyprr1 is offline
