1981 300d 123 130 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-14-2005, 04:21 AM Thread Starter
Vehicle: 1981 300D
1981 300d 123 130
the fuse element inside my pre-glow timer relay is blowm. my "repair manual" states to test the glow plugs w/ohm meter set on 200 range. diconnect glow plug harness connecter at relay & go from ground to each numbered terminal in turn. any infinite reading on meter indicates a defective plug or it's correponding wiring. all 5 of my plugs are showing infinite readings. could they all be bad just like that? is there another way to check them. thanks for the help.[B)]
1981 300D
1964 international harvester C1200
1984 chevy cavalier
5 kids/2dogs
benmaples is offline
post #2 of 2 (permalink) Old 03-14-2005, 05:44 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
RE: 1981 300d 123 130
If the car started before, then some of the glow plugs ought to be good. A good plug tests 0.6 ohms. One lead on the ohm mmeter goes to ground. The other you stick in the harness end connector for each glow plug. I guess you could buy one new glow plug and replace the easiest one and make sure you are doing the test right.
sokoloff is offline
