300 TD waggon problem starting - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-06-2005, 05:11 PM Thread Starter
Vehicle: 1979 300 TD waggon
Send a message via AIM to banditele Send a message via Yahoo to banditele
I have a 79 300D TD Waggon. When I first start it early of a morning it is difficult to start. Temp is about 60 degrees outside. What can I do to make an easier start?
banditele is offline
post #2 of 2 (permalink) Old 03-06-2005, 09:38 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: 300 TD waggon problem starting
You should be posting in the w123 forum, you’ll get more responses.
Check to see if one or both of the fuel filters are clogged. Make sure you’ve got a good battery and starter. Check to see the glow plug relay is good and there is less than .5 ohm resistance on the glow plugs. The fuel tank may be full of algae, which can clog the fuel tank filter screen. The prechambers may be choked with carbon and interfering with the glow plugs. The engine’s compression should also be checked. Use a diesel purge to clean the injectors and reduce smoke and hard starting.
jdc1244 is offline
