Class C 2002 - Starting problems!!!! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-03-2005, 12:56 PM Thread Starter
Hi!!
I have a W203 Class C 220 CDi and today the car refused to start, I turned the key but the car doesn't start.
The problem is that I've been havind this same problem but if I try some more times the car started just fine.
Also when I insert the key all runs normal lights, radio, and ignition lights, etc and no error code appear in the computer.
I've called the MB assistance and they say that I need to switch the starter (about 746 € ), what you think about it...
Thanks for the help!!
sepeca is offline
post #2 of 5 (permalink) Old 03-05-2005, 07:23 PM
JR_Rider's Avatar
Date registered: Nov 2003
Vehicle: 1985 300sd
RE: Class C 2002 - Starting problems!!!!
I am afraid that we will need a little more information to help you with your problem. When you say "it doesn't start" does it turn over, making a clicking noise, or no sounds at all?? Glow plug relay or bad glow plug would be my first guess. And 746 for a starter, you have got to be kidding me. Try some online parts suppliers. I am not sure what country you are in, but I am sure you could find some with parts WAY cheaper than that. A remanufactured starter for your car should not be more than $350, I would think.
JR_Rider is offline
post #3 of 5 (permalink) Old 03-11-2005, 02:48 AM
I live in the UK and I am experiencing the same problem too with an E220cdi and two of my colleagues have the same problem one with an E220cdi,the other with a CLK200 Kompressor--these are all automatics !
jp williams is offline
post #4 of 5 (permalink) Old 03-12-2005, 12:27 PM
zenman 63's Avatar
Vehicle: ML63 AMG & 2 350 SLK with AMG kit.
Quoted: 49 Post(s)
I had a similar problem with my old C 200 K, it was the auto switch inhibiter.
This stops you starting the car in Drive say. The switch was changed under warranty and the problem went away. It did take a long time to find through .
Ian.
zenman 63 is offline
post #5 of 5 (permalink) Old 03-17-2005, 07:10 AM
Many thanks to Zenman 63 for his very helpful information--we`ll now see what the man from Mercedes Benz has to say !!
