tiptronic transmission - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-03-2005, 02:21 PM Thread Starter
Date registered: Feb 2005
Is it advisable to buy this type of transmission. Does anyone know any problem about it- someone has offered to sell an E240 at a very good price but I am not so sure about this tiptronic.
jeckie is offline
post #2 of 5 (permalink) Old 02-03-2005, 06:34 PM
Andrew2004az's Avatar
Date registered: Feb 2004
Vehicle: 02 ML 320
RE: tiptronic transmission
tiptronic is on all new mercedes benz cars(I think they brought it out in 97 or 98 someone correct me if i am wrong) and it is just a way of allowing the driver to select gears. it was built to give drivers the best of both a manual and auto gear box. but it really doesnt give you the manual fell it wont change when you want it to change but that can help you, with the tiptronic you cant downshit and blow your engine like in a manual. basically you wont use it so dont worry at all about it its like having a moonroof in antartica you wont use it, i only use it when i want to downshift on the freeway to pass someone its just a add on to the auto transmission.
Andrew2004az is offline
post #3 of 5 (permalink) Old 08-07-2008, 12:59 AM
Date registered: Jul 2008
which w202 models came standard with tiptronic transmission?
310W202 is offline
post #4 of 5 (permalink) Old 08-07-2008, 09:26 AM
Kajtek1's Avatar
Quoted: 1070 Post(s)
No worry about blowing out the engine with triptronic.
It is electronic transmission and the computer supervise stupid drivers. Even when you shift to reverse at 80 mph.
Not sure about parking.
Anybody has first-hand experience?
Kajtek1 is offline
post #5 of 5 (permalink) Old 08-07-2008, 10:48 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
I don't remember if I've tried park position on the W211 but if you pushing the lever long is a feature where the best gear down is selected at one go (instead of going down by one). I guess some go down multiple gears from a single push too.
Anyway, the park lock is mechanically designed not to engage before the vehicle moves slowly enough (very slowly).
Electronically controlled boxes are not only protected by the computer, they still have the mechanical/hydraulic circuitry too that prevents dangerous gear selections, not sure about the wrong gear but at least a combination of clutches that would destroy the tranny if applied simultaneously. The computer has a small chance going crazy and one cannot afford losing the tranny every time this happens (even if it was one out of billion, it would still mean a lot of broken trannies).
Diesel Benz is offline
