over voltage relay - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-11-2004, 07:17 PM Thread Starter
Date registered: Dec 2004
over voltage relay
is there a way to test this elusive device or is it just hit or miss. many elec demons in 92 300e
jluizzi is offline
post #2 of 3 (permalink) Old 12-11-2004, 08:28 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: over voltage relay
There is not a test per se. If the ABS light is on and the idle rough then the OVP may be bad. You can check the ten-amp fuse to see if its bad by using a good fuse, if it does not work with a good fuse the relay is fried.
jdc1244 is offline
post #3 of 3 (permalink) Old 12-11-2004, 09:56 PM Thread Starter
thanks
jluizzi is offline
