Electric Windows - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 11-26-2004, 02:39 PM Thread Starter
Date registered: Nov 2004
Electric Windows
I have a 1998 W210 E300TD both front windows stop working,sometimes both together somtimes just one (eather one) if you disconect the battery or take out the fuse the window will work again for a few days. we have replaced both the modules/box in the front doors but still have the same problem ??????
a8lsf is offline
post #2 of 13 (permalink) Old 11-26-2004, 09:46 PM
lisnjay's Avatar
Vehicle: 86 420 SEL
Send a message via AIM to lisnjay Send a message via MSN to lisnjay
RE: Electric Windows
May be a long shot, but have you checked the wires in the doors?
Jay
lisnjay is offline
post #3 of 13 (permalink) Old 11-28-2004, 05:33 PM
sleepwalker's Avatar
Date registered: Apr 2004
Vehicle: Mazda 6
power supply interruption.
sleepwalker is offline
post #4 of 13 (permalink) Old 04-14-2006, 10:58 AM
The Machine
Guest
Posts: n/a
Quoted: Post(s)
Hello, I have the same problem - it just started with my left window. I have a 1990 SL500 and my top wont go down unless both windows are lowered. Any ideas?
Thanks, Bob
post #5 of 13 (permalink) Old 12-29-2006, 05:10 PM
Date registered: Apr 2006
Vehicle: CL 600 RennTech
Send a message via AIM to dannydang Send a message via MSN to dannydang Send a message via Yahoo to dannydang
Hi Sleepwalker,
I have the same problem with my CL600. You said "power supply interruption" ...sound right. How do we test or fix it?
Thanks.
Work hard & Play hard...
Life is too short to enjoy... Dammed it!!!
MBZ CL600 RennTech
MBZ S500 Stock
PORSCHE 911 C4
BMW 325Ci Convertible
NISSAN 240SX SE Customized Body Kit
ISUZU TROOPER (RIP 2012 by a DUI person)
dannydang is offline
post #6 of 13 (permalink) Old 03-05-2007, 09:56 AM
Date registered: Mar 2007
Fuses
Hi - I'm getting this problem too. The window and mirror on each of the front doors stop working after a couple of weeks - sometimes one door - sometimes both. To re-set the driver's door (right hand door here in the UK) I have to pull
out and then replace fuse #16 in the fuse box under the bonnet (hood). When I do this I hear a click as if a replay somewhere has been reset.
For the passenger front door (left hand side) I have to pull and replace fuse #1
under the back seat.
Also the front domelight fails to work when a front door is opened about every 3 months - so then I have to pull and replace fuse #4 under the back seat.
A voltmeter shows there is voltage on both sides of the fuses before I pull them.
This is on a 1997 w210 230E.
PhilLondon is offline
post #7 of 13 (permalink) Old 03-05-2007, 01:21 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
That is often caused by rain getting into the doors when rubber seals start to fail as they get older, and shorting out the electrical and mechanical parts...
Don't believe everything you think
Jayhawk is offline
post #8 of 13 (permalink) Old 03-06-2007, 04:42 AM
Rubber seals
Thanks very much for that suggestion, Jayhawk.
In London the car tends to be put away in the garage - but when away for the weekend and it is left out in the rain for a few days, then the problem does seem to happen more often.
post #9 of 13 (permalink) Old 02-20-2008, 09:41 AM
Date registered: Jan 2008
i have the same problem on me 1998 e55. the front pass. window work by removing the no 1 fuse under rear seat and the front drivers - fuse under put your hand below fuse 16 and move the wires around.. good luck
neil dunn is offline
post #10 of 13 (permalink) Old 09-08-2008, 04:33 AM
Date registered: Sep 2008
Hi Guys, I have a 98 e320 and I have intermitten to power to the front doors, it can happen individually, I can reset it back by removing the fuses 1 and 16 as mentioned above , checked the wiring and found no visual deffects, any other ideas...Pls HELP!!!
ClearRealty is offline
