replaced battery/ how to reset codes - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 11-13-2004, 02:16 PM Thread Starter
Date registered: Nov 2004
I have a 1999 Sl500. I just replaced the battery today. Upon replacing, the dash warning lights for "BAS ESP and ABS" are still lit and will not go out. Is there something that I can do to reset, or do I have to take to dealer. Also, left window now will not go back up + I cannot pop hard top. Please help. I don't want to get ripped off by the dealer over replacing a battery.
randywon is offline
post #2 of 12 (permalink) Old 11-13-2004, 04:40 PM
DamnYosh's Avatar
Date registered: May 2004
Vehicle: 2000 E55 AMG
Send a message via AIM to DamnYosh Send a message via MSN to DamnYosh Send a message via Yahoo to DamnYosh
RE: replaced battery/ how to reset codes
I had exactly the same thing happen when the tech replaced the battery on my E55.
After replacing the battery, he put the key in the ingnition and turned the stearing wheel all the way to the left and then all the way to the right, did this three times. That did the steering sensor reset, then he rolled all four windows down and held the switch in down position for few seconds and did the same thing with windows rolled up.
From what I remember, he said that all the sensors will have to learn the positions again. So, when you do all these things, the sensors know where all the extreme positions are.
I did have to take it to the dealer to get the code for my stereo though.
Hope this helps.
DamnYosh is offline
post #3 of 12 (permalink) Old 05-21-2007, 01:08 PM
Vehicle: CLK 430
1999 Clk 430
I am getting the following warning lights when I apply my brakes. BAS ESP and ABS. I have a 1999 CLK 430 ?
jbrown is offline
post #4 of 12 (permalink) Old 05-21-2007, 04:19 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
You've changed the subject.
You need new brake light switch.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 12 (permalink) Old 05-22-2007, 04:51 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Your owner's manual covers what needs to be resynchronized when you replace the battery and tells you how.
sokoloff is offline
post #6 of 12 (permalink) Old 05-22-2007, 05:12 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
I agree, except the guide to turn your steering wheel all the way from one end to the other, I don't remember seeing this on the manual, or have I just missed it.
Diesel Benz is offline
post #7 of 12 (permalink) Old 05-22-2007, 12:57 PM
JOE55's Avatar
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
You may need new battery. if the battery voltage was dropping down under 10 volts at times which is the threshold for the ESP/BAS system according to the Owners Manual.
JOE55 is offline
post #8 of 12 (permalink) Old 05-22-2007, 12:59 PM
JOE55's Avatar
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
Here is a comprehensive list of all items that need (or may need) to be synchronized after loss of power (i.e., battery disconnect):
Synchronizing Head Restraints:
If the power supply was interrupted (battery
disconnected or empty), the head restraints are no
longer adjusted automatically. To resynchronize the adjustment feature, turn electronic key in steering lock to position 2, move the seat completely forward and the head restraint fully down, and hold respective buttons for approximately two seconds.
Synchronizing power windows:
disconnected or low), the windows cannot be opened or
closed by the Express feature. To resynchronize the express feature, press <close> side of power window switch to resistance point until the window is completely closed and hold for additional 2 seconds. Repeat procedure for each window. The automatic full opening and closing procedure of the windows should now be restored.
Synchronizing sliding/pop-up roof:
disconnected or low), or if the sliding/pop-up roof is blocked during closing/opening procedure, the system has to be synchronized. To do so, turn electronic key in steering lock to position 2, move and hold switch in direction (3), until the sliding/pop-up roof is completely raised at rear, and
hold for additional 1 second.
Synchronizing ESP:
disconnected or empty), the BAS/ESP malfunction
indicator lamp may be illuminated with the engine
running. Turn steering wheel completely to the left and then to the right. The BAS/ESP malfunction indicator lamp should go out.
Synchronizing remote control:
The remote control may have to be resynchronized, if
the vehicle cannot be locked or unlocked. To synchronize insert electronic key in steering lock.
The remote control should once again be operational.
JOE55 is offline
post #9 of 12 (permalink) Old 05-22-2007, 07:34 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Since we are dredging up a November 2004 thread, I might as well make a sarcastic comment. randywon made one appearance/post and then disappeared after bashing dealers. Could it possibly be if he had let a dealer replace his !@#$ battery in the 1st place, they would have re-set his codes, and probably at no extra charge?
Musikmann is offline
post #10 of 12 (permalink) Old 05-22-2007, 10:14 PM
Quoted: 37 Post(s)
We can safely assume this. We have another first post without a "thank your" (for lkchris this time). I guess some useful info anyway for others if the couple of original posters did not want to acknowledge that.
