Low oil pressure at idle? Is this a comon problem? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-25-2004, 05:04 PM Thread Starter
Date registered: Oct 2004
Vehicle: 1981 Mercedes 380SL
this car is like new but does not have what I call good oil pressure at idle after it warms up. Is there a high volume oil pump replacement?
buckwyatt is offline
post #2 of 6 (permalink) Old 10-25-2004, 05:28 PM
Date registered: Sep 2004
RE: Low oil pressure at idle? Is this a comon problem?
what kind of car do you have? how many miles on it? did you check your owners manual for proper gauge readings? also, a high flow pump would not be the same as a high pressure pump.
benztech1209 is offline
post #3 of 6 (permalink) Old 10-25-2004, 05:37 PM Thread Starter
So a high volume pump doesn't cause higher pressures?
post #4 of 6 (permalink) Old 10-25-2004, 07:07 PM
no, high volume is high qauntity. high pressure isnt necessarily high volume. in this case, you wouldnt need an "upgraded" pump if your pressure is low. chances are your old pump is just worn out. judging by your other posts though, and that your car only has 17k miles, i would say that it is either low on oil (which i doubt) or its normal. remember, your oil pressure will fluctuate with engine speed.
post #5 of 6 (permalink) Old 10-25-2004, 08:17 PM
jcmbz's Avatar
Vehicle: 111/123/124/126/140/201
I got the same question too. My 230E/560SEL/S500 all have the oil pressure at 2 bar when idle...
However, my E420 has less than 1 bar when the engine is hot. I have brought the car to the dealer and the service manager said it is normal, he step on the gas and said coz the needle will point to 3bars so the it is normal, as long as the car has at least 0.3bar they said it is normal for mercedes
not sure if it is true or not
jcmbz is offline
post #6 of 6 (permalink) Old 10-26-2004, 12:13 AM
Sivonen's Avatar
Vehicle: W123 280E
Yes, over 0.3 is OK at idle.
Sivonen is offline
