GAS - Page 4 - Mercedes-Benz Forum
post #31 of 38 (permalink) Old 10-12-2004, 10:14 AM
Date registered: Apr 2004
RE: GAS
The higher the octane, the better, if in doubt, please contact your chemical engineer.
C.
atomsrock is offline
post #32 of 38 (permalink) Old 10-13-2004, 11:45 AM
RE: GAS
The higher the octane, the better. Consult with your local chemical engineer.
C.
post #33 of 38 (permalink) Old 10-13-2004, 05:49 PM
big_b's Avatar
Date registered: May 2004
Vehicle: 1990 190e 2.6 150k
RE: GAS
Let's all agree to put in what the manual tells us.
And now a new gas issue...
I suggest to everyone buying BP gas. BP has some of the cleanest burning fuels and spends the most money of the major oil companies on researching cleaner gasses and the most environmentally friendly ways of digging for oil.
Also, the BP where I buy gas is significantly lower priced than the Chevron and Shell stations across the street. (Sometimes $1.85 vs $1.95 super--Ah, I love living in Texas...cheap gas! All you other suckers are paying $2.00+).
big_b is offline
post #34 of 38 (permalink) Old 10-14-2004, 05:51 PM
RE: GAS
big_b - 10/13/2004 8:49 PM
A true "Brit" here? Oh, I'm sorry, "Beyond Petroleum", not, "British Petroleum."
C.
post #35 of 38 (permalink) Old 10-15-2004, 04:44 AM
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, CL55, E350, E320
Quoted: 4 Post(s)
RE: GAS
Thanks atomsrock!
lnguyenh is offline
post #36 of 38 (permalink) Old 10-15-2004, 07:35 AM
SledDog's Avatar
Date registered: Dec 2003
Vehicle: 2004 SLK32 AMG
RE: GAS
atomsrock - 10/13/2004 11:45 AM
C.
If your local chem eng told you that, he's either not a chem eng or has never really studied this issue. We could cut the chem eng some slack if he is located in a region that uses RON only instead of (R+M)/2 like the UK, and is referring to that case. Without giving a reason why, it is still not a good generalization. There is no reason to use an octane above one that already meets or exceeds the requirement stated in your manual - although in some regions where RON is used, there might be an exception related to the the "octane" stability.
BP? Haven't heard that one for quite a while. Don't have them in SoCal. In the late '80's, it was ARCO that had patents on the cleanest formula - which they licensed - and the cheapest fuel. One of the things that seems to confuse the discussion of octane are things that do not necessarily affect octane rating, like additives for cleaning. Chevron not too many years ago advertised Techron as only being available in their highest grade of fuel and recommending running 2 tanks of it to "clean your engine". Had nothing to do with the octane rating but it did add to the myth that higher octane fuels burn cleaner or clean better even if your car didn't require that grade. Now Techron is in all of their fuels so their is no reason to use the highest grade if your car doesn't need it.
SledDog is offline
post #37 of 38 (permalink) Old 10-15-2004, 02:20 PM Thread Starter
Gta255's Avatar
Vehicle: 1994 E420
Send a message via AIM to Gta255
RE: GAS
Yeah I know, I'm payin 2.45-2.55 per gallon and it's killing me.
Gta255 is offline
post #38 of 38 (permalink) Old 10-16-2004, 07:43 PM
tiggerfink's Avatar
Vehicle: 2004 SL500 2002 SLK320
RE: GAS
This is from the article that I posted about gas. The Honda lost power with premium gas.
The Accord took a tiny step backward in power (minus 2.6 percent) and performance (minus 1.5 percent) on premium fuel
2002 SLK320
2004 SL500
tiggerfink is offline
