Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 10-07-2004, 06:22 PM   #1 (permalink)
Reggiefd's Avatar
Date registered: Oct 2004
Vehicle: 1984 380SE
Oil Indicator, I do not understand what I am seeing
1984 380SE.
The analog indicator goes from 0 to 3.
While car is in idle mode, the analog meter hangs around 0 to 1.
While normal driving the meter registers at 3 which is the max reading.
Is this normal? I thought most analog meters in a car are set up to have a min and max range. While driving normal speeds, one would expect the analog meter to register in the mid range. Is it normal for the meter to be at the maximum reading or is my oil pressure too high.[?]
Reggiefd is offline   Reply With Quote
Old 10-07-2004, 07:13 PM   #2 (permalink)
danwatt's Avatar
Date registered: Aug 2004
Vehicle: 1990 300SE
Send a message via AIM to danwatt
RE: Oil Indicator, I do not understand what I am seeing
That's normal, except I usually get around 2 for my idle. I have an inline 6 though (1990 300SE).
danwatt is offline   Reply With Quote
Old 10-07-2004, 07:13 PM   #3 (permalink)
Vehicle: 89 300 CE
I just brought a 89 300ce, my oil pressure reading same as yours. I am not sure if it is normal. I checked my oil level and found that it is over the max line. I am going to dump some oil to see what will happen.
new kid is offline   Reply With Quote
Old 10-08-2004, 04:27 PM   #4 (permalink)
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1987 560SEC Now 100K mi.
Hi Reggieffd & new kid,
"The analog indicator goes from 0 to 3. While car is in idle mode, the analog meter hangs around 0 to 1. While normal driving the meter registers at 3 which is the max reading."
As danwatt says: "that's normal". My '87 560 is exactly the same too.
Here is an Oil Pressure snapshot from the MB CDs as reference.
Cheers, MBL
MBL87560SEC is offline   Reply With Quote
Old 10-09-2004, 12:23 AM   #5 (permalink)
barry putnam's Avatar
Date registered: May 2003
Vehicle: 1995 MB S320V: 2006 kawasaki vulcan 900 lt
[:)]bearing in mind that one atmosphere is 14.7 lb. then .3 atmosphere is about 5lb.
so no problem.
Barry
BECAUSE SIZE REALY DOES MATTER, W140
barry putnam is offline   Reply With Quote
