Strange Problem '92 MB 500 SL - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-10-2004, 12:24 PM Thread Starter
Date registered: Sep 2004
I have a '92 MB 500 SL with a strange problem. The left front park light and left rear tail light inadvertently come on together for no reason. (I do not have the headlight switch set to that position!)
It does not matter what position the ignition switch is turned. It will do it sitting in a parking lot, locked up, or driving down the road. If the car is parked usually once these lights come on they stay on until the battery goes dead, however, while driving they may come on for a while, then go off, repeatedly. When these lights come on the left turn signal indicator is illuminated, and the left turn signals do not flash. Flipping the headlight switch around to different positions has no effect to make them turn off or on. Sometimes they may not come on for a week.
I've checked the bulb for a crossed filament and found none. A Benz mechanic told me it was probably the hazard relay so I replaced it, but it did not fix the problem, however, if you unplug this relay while these lights are on, removing fuse #9 makes them go off but the hazard relay starts clicking like crazy. If these lights are not on, removing fuse #9 has no effect on the hazard relay!
Can anyone out there help?
Email swv72@yahoo.com
shanevauctions is offline
post #2 of 4 (permalink) Old 09-11-2004, 10:23 AM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: Strange Problem '92 MB 500 SL
its normal, when you indicate to go left and park up and forget to reset the stalk and turn the ignition off the indicator/flasher then becomes a parking light for that side lights only, its used when parking in a poorly lighted area so you don't have to leave all the lights on
teky is offline
post #3 of 4 (permalink) Old 09-11-2004, 11:13 AM
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, CL55, E350, E320
Quoted: 4 Post(s)
How could that be normal teky ... I don't know how to fix it but it doesn't seem normal to me. Are you normal? [:D]
lnguyenh is offline
post #4 of 4 (permalink) Old 09-23-2004, 03:47 PM
Date registered: Feb 2004
Vehicle: any benz on the lot
sounds like a bad light switch module. I've seen it a couple of times.
-scott
MB Tech
couldnthinkaone is offline
