Help req viscous fan removal E320 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-09-2004, 11:26 AM Thread Starter
Date registered: May 2004
Anyone know how to remove the viscous fan on a 96 E320 with the 104 engine (petrol), there is not the usual big nut and the four bolts that hold the hub on can only be loosened so far before the heads hit the fan hub.
Any ideas much appreciated.
Lynall
Lynall is offline
post #2 of 5 (permalink) Old 09-09-2004, 11:52 AM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: Help req viscous fan removal E320
there has to be bolts holding the fan blades on also a larger nut for the viscus hub and one at the rear to lock it so you can remove the unit thats the only way you can remove them, take a picy so i can have a look
teky is offline
post #3 of 5 (permalink) Old 09-10-2004, 12:03 PM Thread Starter
Teky
I have picked up the new hub from mercs today and it is a press fit on to the shaft so it looks like i will have to undo the four bolts and press old one of and refit new one on.
Will let you know tomorrow as i will be doing this and a front reline.
Meant to say book time is only 35 mins.
Lynall
Lynall is offline
post #4 of 5 (permalink) Old 09-10-2004, 10:29 PM Thread Starter
Just a simple cap head through the centre of the fan assembly.
Lynall
Lynall is offline
post #5 of 5 (permalink) Old 09-11-2004, 10:25 AM
teky's Avatar
Vehicle: chris
glad you got it sorted[:)]
teky is offline
