Applying new badges (need help) - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-07-2004, 08:21 AM Thread Starter
Date registered: Aug 2004
Vehicle: 2005 CLK 320 Conv.
I am applying new badges to rear trunk. Can anyone suggest how to properly align so they are straight and look as close to new as possible???
bforde is offline
post #2 of 8 (permalink) Old 09-07-2004, 08:51 AM
Kühl Carbon's Avatar
Vehicle: 1999 SLK230
RE: Applying new badges (need help)
I would apply a piece of tape along what will be the bottom edge of the letters. You can then use a level, or stand back and look at the tape from several different angles to make sure it is in the proper location and is level. Then you just apply the bottom edge of the letters at the top edge of the tape (assuming an OEM style badge) and peel off the carrier, peel away the alignment tape, and VIOLA!
Hi []
Kühl Carbon is offline
post #3 of 8 (permalink) Old 09-07-2004, 09:42 AM
Storm's Avatar
Date registered: Jan 2004
Good call.
Storm is offline
post #4 of 8 (permalink) Old 09-07-2004, 11:39 AM Thread Starter
Thanks, as the old badge is no longer there, is there specific placement it should go, like two inches to the left and x amount of inches from the center, or does that sound silly I am being so particular? This is for the badges on the right side of the trunk.
Many Thanks
bforde is offline
post #5 of 8 (permalink) Old 09-07-2004, 12:33 PM
lnguyenh's Avatar
Vehicle: SL500, CL55, E350, E320
Quoted: 4 Post(s)
I think the best way should be coming to the dealer lot, park next to a car and apply your badge [:)]
lnguyenh is offline
post #6 of 8 (permalink) Old 09-07-2004, 09:38 PM
cvayala's Avatar
Date registered: Aug 2003
Vehicle: SLK32
Send a message via AIM to cvayala Send a message via MSN to cvayala Send a message via Yahoo to cvayala
I just did this, I used a horizontal piece of tape as mentioned above, then I referenced a couple of pictures and used a vertical piece of tape to mark off the end.
2002 SLK32 AMG - RennTech Pulleys, RennTechCams, RennTech ECU,
RennTech wheels (18x9.5 265/35 rear, 18x8.5 235/40 front) - BVRC - Illuminated door sills - Wood trim - Escort Passport SRX
cvayala is offline
post #7 of 8 (permalink) Old 09-07-2004, 11:01 PM
Blast26's Avatar
Vehicle: 2005 C230WZ
What happened to the original badges? Seems like alot of people are getting their badges stolen. I hope thats not the case for you.
Anyways I would use the tape method as well as going to the dealer and parking right next to a car on the lot.
Blast26 is offline
post #8 of 8 (permalink) Old 09-08-2004, 11:27 AM Thread Starter
Actually I took mine off. I think I like it better on.
bforde is offline
