don't fill your tires with air - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 09-13-2004, 10:08 PM
Date registered: Aug 2004
Vehicle: 1989 300TE
RE: don't fill your tires with air
The sole advantage is: nitrogens thermal stability compared to 'regular' air. Racers have been doing this for a few (maybe more) years. But if your not racing then the thermal expansion of the 'gas' inflating your tires is not that big a deal, or maybe it is...?
miked
miked300TE is offline
post #12 of 20 (permalink) Old 09-14-2004, 02:17 AM
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
miked300TE - 9/14/2004 1:08 AM
miked
Its not even April first. The reason for using a pure gas instead of air is to predict the inflation pressure in direct proportion to heat. This is of course well documented in your high school science textbooks.
Now if you move to the next chapter you will read about chemical equilibria and the effects of smog at different temps. As the temp rises the pollutants in air form alternate compounds leading to an uncertainty in the final molar mass of the air in the tyre and leading to a shift in the final volume and subsequent pressure. All of which is totally reversed on cooling.
total unknown volume results in errors of 1% which is measureable in racing cars. The application on planes is that an exploding tyre does not combust its contained gas when landing.
Modz ... enjoy the difference. www.benzmodz.com
miroj is offline
post #13 of 20 (permalink) Old 09-14-2004, 11:31 AM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
N2 is also dry. Have you ever seeen the moisture around the valve stem when adding air to a tire? That moisture ends up inside the tire and stays there until the tire is removed from the rim. I used to have some alloys that were real "mags" ie: MG and they corroded really badly from humid air being pumped into them.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
post #14 of 20 (permalink) Old 09-14-2004, 12:05 PM
n5160u - 9/14/2004 2:31 PM
Metal in the alloys or Mg as you point out can only corrode when in contact with another metal of a different potential, like the wheel nuts, the hub and balancing weights. Yes, the small weights on the rims can corrode the metal.
The contained water on the other hand does nothing because it can not form a circuit.
The same thing happens when you mismatch the metals in any type of multi-component system. The several metals form a battery where electrons migrate (from the rims in your case) to the car or from the car. That and the fact that under enormous stress metals are constantly reworked and the crystals fatigue.
The most likely cause of metal degradation in alloys is
- electrolytic oxidation
- impurities
- stress
- uneven cooling or poor casting
Water inside the air inside the tire would only do something if the rim was attached to ground with an earthing strap, such as might happen in storage.
That would be the Science chapter on Galvanni and electricity.
miroj is offline
post #15 of 20 (permalink) Old 09-14-2004, 02:21 PM
Vehicle: 1989 300TE
No need for smart alec remarks, miroj.
How does your 1st paragraph differ from my post that you so graciously quoted.
'Thermal stability' ~ two words (perhaps a euphemism) to express your whole missive...
post #16 of 20 (permalink) Old 09-16-2004, 06:10 PM
Date registered: May 2003
"Why not fill your tires with Hydrogen? It did wonders for the hindenburg"
Eiknujzneb is offline
post #17 of 20 (permalink) Old 09-16-2004, 06:59 PM
miked300TE - 9/14/2004 5:21 PM
Perhaps not as it would need to be described as thermally unstable. But if you can detect 1% variations then knock yourself out - call it what you will.
All gases obey the same law when heated unless they undergo secondary reactions.
miroj is offline
post #18 of 20 (permalink) Old 09-16-2004, 09:58 PM
EVERYONE RELAX.......HAVE A GOOD TIME.
These Benz forums get so so uptight sometimes.
teech is offline
post #19 of 20 (permalink) Old 09-17-2004, 02:12 PM
Date registered: Jun 2004
Send a message via AIM to BenzGirl04
Oops To Late. I already filled my tires with air from local gas station. Needed to get them filled up. Will it do anything to the tires?
BenzGirl04 is offline
post #20 of 20 (permalink) Old 09-17-2004, 02:14 PM
BenzGirl04 - 9/17/2004 5:12 PM
At a guess it will make them work properly.
miroj is offline
