300SE engine rpm speed - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 09-01-2004, 05:04 PM Thread Starter
Date registered: Sep 2004
What should the engine rpm be at 70mph speed on a 91 300SE? I don't believe my car is shifting into 4th gear. Seems to be running fairly high rpm at highway speeds. (approx 3600rpm at 70mph)
dvxpert is offline
post #2 of 15 (permalink) Old 09-01-2004, 08:23 PM
jzaroh's Avatar
Date registered: May 2003
RE: 300SE engine rpm speed
Nobody's answered your question yet?
Sounds accurate more or less in top gear. Should be around 3500 at those speeds. Remember it has a 3.46 differential, so it is not a lazy engine.
jzaroh is offline
post #3 of 15 (permalink) Old 09-01-2004, 08:26 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
It's normal:
http://www.mbnz.org/forums/forums/thread-view.asp?tid=305040&posts=10&hl=rpm+300+sel
jdc1244 is offline
post #4 of 15 (permalink) Old 09-02-2004, 02:50 AM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
(approx 3600rpm at 70mph) thats way too high its a six cylinder and they normaly run at 2000rpm to 2500 at 70mph i would say its not useing 4th gear at all, check the kickdown settings are right
teky is offline
post #5 of 15 (permalink) Old 09-03-2004, 07:51 AM
matteus's Avatar
Date registered: Jan 2003
Vehicle: Mercedes-Benz
no it's normal..
our 300E also runs about 3400-3500 at 120kph.
They do not run at 2000rpm at these speeds.
matteus
1991 MB 300TD: daily driver, going strong at 474.000kms
1991 MB 190E 1.8
1983 MB 190E 2.0 AMG 145PS: Restauration project up next...
2001 Alfa Romeo 147 2.0 16V Selespeed
matteus is offline
post #6 of 15 (permalink) Old 09-03-2004, 08:06 AM
teky's Avatar
Vehicle: chris
odd one that then, ok if its a 3 speed box i would agree
teky is offline
post #7 of 15 (permalink) Old 09-03-2004, 08:10 AM
00 ML430 Bulldog's Avatar
Date registered: Mar 2003
Vehicle: 2000 ML430
dvxpert - 9/1/2004 8:04 PM
That RPM is way too high for 70MPH.
ONE TUFF LOOKING ML!!!
00 ML430 Bulldog is offline
post #8 of 15 (permalink) Old 09-03-2004, 11:17 AM
Date registered: Aug 2004
Vehicle: 300te 4 matic,260e,
hi,
I have 1989 300te,only had it couple of months,was really shocked.100 MPH RED on tacho,did post about it, was concerned,engine smooth as silk.Checked as much as I could,tyre size ok,gearbox seemed right numbers,checked speed with gear changes,etc. etc.
few months after that,more confident etc.the car goes through the red on the tacho stops at a spot with no numerals indicate about 7500 rpm no rev limiter,speedo indicates 130mph,I get scared because of rev counter,but worked with engines for long time, engine doesn't seem stressed ,so concluded that speedo or rev counter error[}:)]All on purpose built track of course[^]
gregit is offline
post #9 of 15 (permalink) Old 09-03-2004, 11:18 AM
teky's Avatar
Vehicle: chris
i agree oo a 4 banger would produce high revs at the speed but not a sweet six
teky is offline
post #10 of 15 (permalink) Old 09-03-2004, 11:27 AM
teky's Avatar
Vehicle: chris
track cars are totally different mine hits the limiter and beyond in every gear but thats a standard dash not capable of measuring the torque and speed that i do so i use a digital read out
teky is offline
