water leak - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-31-2004, 07:17 PM Thread Starter
Date registered: Aug 2004
water leak
I found a water leak in my 1996 C220. It seems to be coming in from the main drain system off the windshield. Water leaks into the passenger cabin on the passenger side. I ran water through the grille areas between the windshield and hood compartment on both sides and it was gushing into the compartment.
Could this be a clog, or do I have a bigger problem? I popped the plastic grilles off and it looks like there are screws holding in the grille frame work. How can I get to the tube to see if there is a clog?
Thanks
benzblonde is offline
post #2 of 3 (permalink) Old 09-02-2004, 03:36 AM
Date registered: Oct 2003
Vehicle: CL500, E430, SLK, Subaru...
RE: water leak
Do you have aircon?
It could be that there's a clog low down in the drain system for the aircon condenser - most C classes will leave a 'wee pool' on the ground on hot days if their drain tubes are working right. You really have to approach the clog from the bottom, not the top...
Steve
London, right in the middle
03 CL500 (Black/Grey, 48k, Comand, 7GTronic, Keyless Go) 302 Bhp
01 E430 (Silver/Black, 112k, Comand, Lingua, 7 seats, tow...) 275 Bhp
97 SLK (40k, Yellowstone, partner's car!) 200 Bhp
03 A210 AMG (Black/Black, 63k, project rescue car) 140 Bhp
...I make that 917 Bhp...!
LondonThing is offline
post #3 of 3 (permalink) Old 09-02-2004, 08:41 PM
Date registered: Sep 2004
Vehicle: 98 C280
RE: water leak
I had the same problem you described in my 1998 C280
The grill was easy to remove -just pay attention to the clips and the direction it snaps together after you remove the screws. (I used a flat screwdriver to assist with the clips) Under the grill you described is the intake area for fresh air for the AC. Mine was just a "flap" that opened and closed with the AC from fresh air to recalculate. The drain was stopped up with trash (dirt, leaves and dirtdobber nest). I also removed the panel under the glove box and carpet. I then removed the cover over the blower motor and found that the charcoal filter was wet and trashed as well as the fan motor area. I dried it all out and have had no more problems. My AC also works much better now [:D] !!! Hope this helps someone else.
2CUTE4U is offline
