1984 380 SE--Acceleration problems, hard shifting - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-24-2004, 03:29 AM Thread Starter
Date registered: Aug 2004
Send a message via AIM to IMnotDAVIDxnsx
This problem is intermittent. When it first began to develop, almost a year ago, the car would run fine at a dead start in the cold moring, but would bog down as the car warmed up. Since then, the idle control valve, spark plugs, vacuum advance, fuel injector seals, catalytic converter (pre and plain ol' cat), and fuel distributor have all been replaced in an attempt to solve this problem. Currently, the car acts bogged down 98% of the time. The other 2%, only moderately bogged. It no longer changes depending on morning or afternoon (but the fact that it's summer could have something to do with that.) You can be depressing the gas pedal at 30 degrees, for example, and keep it there--the car will crawl and then pick up horsepower at a random point during the acceleration. Sometimes, the pick up in horsepower is immediately followed by a car shuddering and teeth clenching shift up into the next gear. Any suggestions? So much money has gone into this problem. I am about to give up. I will be happy to answer any other questions about the car if need be to help diagnose.
-david
IMnotDAVIDxnsx is offline
post #2 of 5 (permalink) Old 08-24-2004, 06:40 AM
Date registered: Dec 2003
Vehicle: 2002 CL 500
RE: 1984 380 SE--Acceleration problems, hard shifting
just a shot in the dark, but do you think it could be a failing fuel pump? don't know if you had this checked but it would cause all those symptoms. how is the fuel filter? could also be ignition timing problem good luck.
reliablebruce is offline
post #3 of 5 (permalink) Old 08-24-2004, 08:45 AM
Guest
Guest
Posts: n/a
Quoted: Post(s)
Hi David.
Have you checked the engine timing?
It sounds alot like what my Camry used
to do,but while slowing down for any reason,
and then hitting the gas again while the car was still moving, would make it bog down.
Mine was the timing.
I had changed the timing belt and the belt
had jumped a tooth.
Putting it back the right way fixed my problem.
So,if the timing wasn't checked I would do so
ASAP.
What about the cap, rotor and spark plug wires?
Have they been replaced?
How do your battery cables look like?
Corroded,clean,chaffing?
As to the shifting that to should return to
normal once the problem is fixed.
Since the engine generates vacuum and the
tranny is vacuum assisted, the way the engine
is running now it won't generate enough vacuum
thus the tranny problem.
Hope this helps.
Louis.
post #4 of 5 (permalink) Old 08-24-2004, 08:51 AM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
do a compression test it could also be worn valves and or lobes on the cam, timing is a real good one and also filter, is the top end tapety like the valves need resetting all these will cause lack of power
teky is offline
post #5 of 5 (permalink) Old 08-25-2004, 12:40 AM Thread Starter
oh yes, i completely forgot--the fuel pump has also been switched out to a more heavy duty after-market one for that year.
