Starting Failures *URGENT HELP NEEDED!! - Page 4 - Mercedes-Benz Forum
post #31 of 45 (permalink) Old 08-28-2004, 09:43 AM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: Starting Failures *URGENT HELP NEEDED!!
wow it got through[:D] only joking hehehe but good luck[:)]
teky is offline
post #32 of 45 (permalink) Old 08-28-2004, 03:34 PM
SledDog's Avatar
Date registered: Dec 2003
Vehicle: 2004 SLK32 AMG
the_girl_i_love - 8/28/2004 8:40 AM
Refering to the attached results,the conclusion to solve the problem is to replace an alternator. I'll to see what i can do and i'll update you guys.
Ok, so new battery. You drive enough that the alternator should be able keep up the charge. There is only one thing you should do before you go and get a new or rebuilt alternator, test the voltage at the alternator. There is always a chance there is a bad wire/connector or something else in series with the alternator that is causing the voltage to be low at the battery. If the voltage at the alternator is below 13.5 V, it needs to be replaced. If you can check the field voltage that would be great too. If it less than 12V, also not good.
Normally shops don't rebuild your alternator. Normally rebuilts are done by a shop that tests them fully and are almost as good as new and much less expensive. Make sure you get a warranty on that part either way you go.
SledDog is offline
post #33 of 45 (permalink) Old 08-28-2004, 08:26 PM Thread Starter
Date registered: Aug 2004
Haha, you got me there teky, anyway it gave me some light at the end of the tunnel i hope. Seriously, do you know what the results that i uploaded mean?
SledDog - 8/27/2004 5:34 AM
There is only one thing you should do before you go and get a new or rebuilt alternator, test the voltage at the alternator. There is always a chance there is a bad wire/connector or something else in series with the alternator that is causing the voltage to be low at the battery. If you can check the field voltage that would be great too. If it less than 12V, also not good.
Where and how do i
1. test the voltage at the alternator? (All the readings i had been getting was from the terminals at the battery)
2. test the field voltage? I am not sure whether i could have a reading around 12V?
the_girl_i_love is offline
post #34 of 45 (permalink) Old 08-29-2004, 08:26 AM Thread Starter
Guys, know what is the part on the pictures above? Got it out of my alternator!
post #35 of 45 (permalink) Old 08-29-2004, 01:55 PM
teky's Avatar
Vehicle: chris
thats the regulaor and carbon brushes "you mentioned they changed it free" and i can assure you its not new due to the wear on the brushes
teky is offline
post #36 of 45 (permalink) Old 08-29-2004, 06:57 PM Thread Starter
So this is the voltage regulator and carbon brushes. Actually, the one in the picture is the old one that was removed 2 weeks ago. I am now using a new unit.
*By the way, how do you upload a pic in a new post?
post #37 of 45 (permalink) Old 08-30-2004, 05:57 AM
teky's Avatar
Vehicle: chris
upload the same as you just did with you last pics, just remember to put a tick in the box on the bottom left where it say "attach a file after posting" then you will be offered the chance to brouse you computer for the picture you want to display
teky is offline
post #38 of 45 (permalink) Old 08-30-2004, 06:43 AM Thread Starter
Thanks for the tip Teky,
By the way, do you know what is a RCL control module?
post #39 of 45 (permalink) Old 08-30-2004, 07:30 AM
teky's Avatar
Vehicle: chris
could be remote central locking at a guess
teky is offline
post #40 of 45 (permalink) Old 08-30-2004, 09:49 PM Thread Starter
Thanks Teky,
Do you know what is DTC B 1703?
Is it a faulty code of some kind?
