windows on my clk - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-15-2004, 05:12 AM Thread Starter
Date registered: Aug 2004
windows on my clk
just sold my sl and bought clk cab 320 s reg should the windows drop and rise slightly when using doors?
mine dont so you have to slam doors any ideas of problem
cartorque is offline
post #2 of 5 (permalink) Old 08-15-2004, 08:18 AM
Date registered: Dec 2003
Vehicle: 2002 CL 500
RE: windows on my clk
if you have the same system IHAVE ON MY CL 500 when you open the doors from inside or out the windows drop down a 1/4 of an inch to clear the weather stripping, if your door is open, make sure the window is down some when you close the door or else the window will strike the weather stripping and wear it out . good. luck
reliablebruce is offline
post #3 of 5 (permalink) Old 08-15-2004, 04:54 PM
w108's Avatar
Date registered: Apr 2004
Vehicle: None
Yes, the same thing happens on Audi and VW coupes/convertables - it's to get a tight seal.
Tory
1990 560SEL - W126
-929 nautical blue metallic & 262 navy blue leather
-58,000 KM (36,200 Miles)
-Euro spec Japanese import (KAT edition)
-Complete service history since new
-5,546cc SOHC 16v V8
-10.0:1 compression
-285 hp@5200 rpm, 324 lb/ft@3750 rpm
-2.65 limited slip diff
w108 is offline
post #4 of 5 (permalink) Old 08-16-2004, 07:25 AM
Mark08859's Avatar
Date registered: Jul 2003
You should double check this, perhaps with your dealer or researching your manual. I don't believe the CLK windows do that, just the windows on a CL class.
'08 C300 Sport/Barolo Red/Gray-Black Leather/6 SP/AMG Wheels/iPod/P2/MultiMedia/Tele Aid
'09 Pasion Coupe/Gray Metallic/Black Tridion/Comfort Package/Solid Roof/Premium Sound/Fog Lights/Clock-Tach/Anti-Theft/Navigation/Bluetooth
Mark08859 is offline
post #5 of 5 (permalink) Old 08-16-2004, 09:10 AM
Vehicle: 2004.5 C 230K SS
Send a message via AIM to jsloan01
Definitely check your manual and your dealer. I am almost positive the windows should drop on your 320 CLK. I was in a 04 CLK 500 last week and the windows worked exactly as described. Good luck!!!!
jsloan01 is offline
