AC relay switch 1991 300 CE - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-13-2004, 09:09 AM Thread Starter
Date registered: Aug 2004
I live and work in Canada and imported a 1991 300 CE from Germany WDB1240511B507018. I am having problems with the A/C and contacted the Mercedes Technical helpline to be told that my particular model was not fitted with A/C. All though it appears it was fitted at the factory I must assume it was a retro fit albeit with Mercedes parts. Several technicians including the main dealership in Calgary have looked at it and they cannot find the A/C relay switch. We have tried behind the battery and in the dash but with no success. I do not know if it helps but the car has a sportline suspension and was wondering if the retrofit could have been done at the same time, and maybe has some bearing on the location of the relay?
majordave is offline
post #2 of 2 (permalink) Old 08-20-2004, 03:39 PM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: AC relay switch 1991 300 CE
they did come with aircon look in the fusebox under the bonnet/hood and you will notice some relays, from the bottom there are 5 numbered from left to right 1-5 ( 2 and 3 are the ac relays ) the other relays are in banks of 3 in the middle and 2 at the top, fuses F7 F8 and F20 are also for the aircon both 16 amp
teky is offline
