ruff idle - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-10-2004, 09:31 PM Thread Starter
Date registered: Aug 2004
ruff idle
I own a 1988 420 sel with 115,000 mi,its beautiful, everthing works ,great body ect.. just filled up with high-test started running & ideling ruff. might be bad gas?? ran it down to half tank filled with sunoco 94 and fuel line/jet cleaner. still runs ruff.. all visibal vacum lines seem ok pushed down on all plug wires.. could it be plugs>> what do you think?? please advise .. thanks T
tenrten is offline
post #2 of 5 (permalink) Old 08-10-2004, 11:33 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 197 Post(s)
RE: ruff idle
I'm assuming you ran some sort of fuel injector cleaner. If this is so, then all the gunk inside the engine might have clogged up the fuel filters. Clogged fuel filters will cause less fuel to be pumped into the engine, hence the rough idle.
I'd look into replacing those fuel filters first.
MBeige is offline
post #3 of 5 (permalink) Old 09-20-2004, 07:58 PM Thread Starter
RE: ruff idle
thanks much did all that changed plugs, wires, rotor, now i am told i need a fuel dist head.. can anyone help in locating one for less than the $2400.00 !!!!! that the dealer wants.. ?? help ..thanks tony i
tenrten is offline
post #4 of 5 (permalink) Old 09-21-2004, 06:43 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1987 560SEC Now 145K mi. (Summer 2016)
Quoted: 114 Post(s)
RE: ruff idle
Hi Tony,
See German Star, a BenzWorld supporter, for your needs. Good quality parts & especially service. Below is the link for your fuel system parts. I think you will be pleased.
Cheers, MBL
MBL87560SEC is offline
post #5 of 5 (permalink) Old 09-21-2004, 10:17 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: ruff idle
Welcome to the forum and the world of rough/high idle in the w126. Here are some things to check:
1. Idle control valve
2. Idle control unit
3. OVP relay
4. Throttle position switch
5. Worn injectors
6. Broken/brittle/missing/disconnected vacuum hose(s)
From your description number 4 may be a good place to start:
Post in the w126 forum from now on – lots of very experience folks there to help because we have the best MBs ever made.
jdc1244 is offline
