300sd turbo fuel problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-01-2004, 04:39 PM Thread Starter
Date registered: Aug 2004
Vehicle: 1987 420SEL 220k mi.
After driving for a few miles, I turn my engine off and when I try to restart it, it is like no fuel is getting to the engine. I use the manual pump and it eventually starts. When this happens my alternator light comes on and all of my gauges are dead. After a few seconds I shut down again and immediately restart and everything returns to normal. What is causing this and what do I need to so to fix the problem?
aucaster
aucaster is offline
post #2 of 4 (permalink) Old 08-01-2004, 05:16 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: 300sd turbo fuel problem
Just curious, w116 or w126? Not that it really makes any difference, I guess…
How many miles? Maybe dirty fuel filters, air in the fuel system? Algae problem, clogged fuel tank screen?
The alt light could be a bad voltage regulator, loose belt, or bad battery, there could be an electrical problem effecting the glow plugs and/or relay. How long does the glow plug light stay lit?
I’d replace the fuel filters if they have not been changed in the last year.
Let us know.
jdc1244 is offline
post #3 of 4 (permalink) Old 08-14-2004, 05:06 PM Thread Starter
It is the w126 and just turned 253,000 mi.. I changed the in-line filter, the transparent one, and the problem with starting has gone away. I put some LUCAS fuel treatment in and it runs much better. The battery and the alternator are both new and the belts are tight. Maybe I will treat it like a sore **** and not screw with it.
Don
aucaster is offline
post #4 of 4 (permalink) Old 08-14-2004, 05:12 PM
jdc1244's Avatar
…sounds like a plan…
Perhaps with the clean filter and fuel system the engine will run better and the other problems will not reappear.
jdc1244 is offline
