AC whistle noise - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-27-2004, 10:28 AM Thread Starter
Date registered: Jul 2004
AC whistle noise
I drive my 2000 E-320 without the radio on most days, and when the AC is on I hear a slight whistling sound coming from it. If I turn the AC off the noise stops, so I know it's coming from the AC vents. Is there anything I should do or could lubricate to stop that whistling noise??
Thanks Much,
BobB
BobB is offline
post #2 of 4 (permalink) Old 07-27-2004, 10:32 AM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: AC whistle noise
check for leaves lodged in the air intake and vents, nothing to lubricate in there otherwise
teky is offline
post #3 of 4 (permalink) Old 07-29-2004, 08:43 PM
Date registered: Dec 2003
who ever did ur vehicles service did not reinstall the cover for the ventilation dust filter properly which is located behind the glove box.
karwerk is offline
post #4 of 4 (permalink) Old 07-29-2004, 10:27 PM
Vehicle: 1978 450SE
Send a message via AIM to RoxyBlonde451
If it is a whistle noise coming from the center vent, then that would mean your freon is low, and there is a leak in the system somewhere, if you don't get it checked out, then eventually you will have nothing in the system, and it could do damage to the compressor. It's the freon whooshing through the evaporator that you are hearing, it won't make that noise if the system is fully charged.
I get that complaint a lot at work, and it is always the same thing. Always W210.
RoxyBlonde451 is offline
