Desperate for electrical fix - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-24-2004, 01:20 PM Thread Starter
Date registered: Jul 2004
Vehicle: 98 C230k
I have a 98 230k c class with intermitant front window failure, which is driving me mad!! the windows keep failing to operate, if I disconect the battery for a few minutes they will work again, but after a few hours or days thay fail again. Sometimes it may be only one window but today after resetting them this morning after disconnecting the battery, both have failed again this afternoon.
Can anyone help or car will have to go!
timbo is offline
post #2 of 7 (permalink) Old 07-24-2004, 01:57 PM
Vehicle: W203
RE: Desperate for electrical fix
timbo - 7/25/2004 9:20 PM
If you have been disconnecting your Battery the Windows may require resetting.
try this....
Lower each window a little and then close using the first button position and keep the button pressed until you hear a click in each door, in turn. Takes about 2-3 seconds per window, the same with the sunroof if you have one.
Joe
Joe_Barton is offline
post #3 of 7 (permalink) Old 07-25-2004, 10:39 AM Thread Starter
Vehicle: 98 C230k
cheers Joe, yeh, been there done that, its the total failure that's the problem, even if you don't reset them they still work, mine don't when the fault occurs.
Thanks, Timbo
timbo is offline
post #4 of 7 (permalink) Old 07-25-2004, 11:58 AM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
it could be a faulty window control module it might be overheating
http://www.benzworld.org/publications/pub.asp?id=267
teky is offline
post #5 of 7 (permalink) Old 07-26-2004, 05:26 AM Thread Starter
Vehicle: 98 C230k
Thanks Teky that sounds like the place to start, unfortunately the manual sheets I printed from your link arn't clear enough for me to read, even with my glasses on. Can you tell where to look for the window control module?
Regards, Timbo
timbo is offline
post #6 of 7 (permalink) Old 07-26-2004, 11:50 AM
teky's Avatar
Vehicle: chris
white dot item 2 page 129, in the trunk passanger side usa behind the carpet
teky is offline
post #7 of 7 (permalink) Old 07-29-2004, 01:09 PM Thread Starter
Vehicle: 98 C230k
Hi Teky,
can't see any module in the booy/trunk, thare is a relay near the fuse box and a white plastic box by the jack. As I don't have a manual i can't check out the pages you quoted.
Maybe mine is an early 98? I vivited the dealership yesterday and a very helpfull mechanis there said they had had a similar problem with another c class and the fault was in the switch block around the gear selector, what do you think?
Regards, Timbo
timbo is offline
