bas/esp idiot light ??? - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 08-26-2006, 04:28 PM
Date registered: Jul 2006
Vehicle: 2002 S430
I had 4 malfunctions when my EIS was bad:
bas, esp, airmatic, stop light, abs(abs light used to come on but wouldnt read as a malfunction).
All were cleared when the EIS was replaced.
I hope this helps.
Sam
02 S430
samiams430 is offline
post #12 of 18 (permalink) Old 08-27-2006, 12:40 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Originally Posted by made.red
I have a 2000 S430, and the ESP, BAS and Airmatic malfunction lights are on. The manual says that if the BAS registers a malfunction, then the ESP light will also come on. But why the Airmatic light?
I was told by a dealer that I need to replace the ESP Switch. Any idea how much that will cost for my model.
Other than that, the car is great.
If you're getting an airmatic malfunction, I'd have it checked out by the dealer. If your car drops it can damage the struts and that is an expensive repair. My car was seriously lower at all four corners about five years ago, and they told me to drive carefully to the dealer. I didn't get the malfunction but ended up paying about $900 for a new air pump.
Don't believe everything you think
Jayhawk is offline
post #13 of 18 (permalink) Old 08-27-2006, 12:43 PM
Jayhawk's Avatar
This is crazy, because the Airmatic light came back on when it is supposed to be fixed. The servicepeople say that replacing the EIS will turn out all of the lights, but another Benz mechanic said that EIS has nothing to do with Airmatic.
Im beginning to think that I am either being 1) treated like I will believe anything or 2) they don't really have any expertise in Mercedes like they claim.
I'm no expert, but I don't think the airmatic is related to the other thing.
Jayhawk is offline
post #14 of 18 (permalink) Old 08-28-2006, 07:39 AM
made.red's Avatar
Date registered: Aug 2006
I am going to replace the EIS unit and see where it takes me. I hope the air pump is not going bad. Was there any noise or any other sign that the air pump was bad?? Did you have any idea that the car was lower at the corners aside from the smoothness of the ride.
made.red is offline
post #15 of 18 (permalink) Old 08-28-2006, 09:38 AM
Jayhawk's Avatar
No noise. No warning. I came out one morning and there it was, sitting several inches lower than usual... I dorve it very carefully to a breakfast meeting and then straight to the dealer in K.C.
Jayhawk is offline
post #16 of 18 (permalink) Old 05-29-2008, 06:47 PM
yayaz23's Avatar
Date registered: May 2008
Vehicle: 2001 mercedes S430, 2010 mercedes E550 4matic
Quoted: 24 Post(s)
Send a message via MSN to yayaz23
Originally Posted by samiams430 View Post
Could be a lot of things from steering angle sensor to EIS.
Need to pull codes
In my case it was the EIS unit.
Parts and labor ( need to program the keys). was under $800.
Sam
02S430
i had my esp switch rplaced it only costed me 120 for the esp release switch on the brake booster
yayaz23 is offline
post #17 of 18 (permalink) Old 07-24-2010, 08:44 AM
Date registered: Jul 2010
ml 320 bas esp
i found my problem after i replace BRAKE PRESURE SENSOR on the master brake cilindre light bas esp off and car works good .i found on ebay all master brake cilinder for $100
bezborodko is offline
post #18 of 18 (permalink) Old 08-25-2011, 04:19 AM
Date registered: Aug 2011
Vehicle: a class A16 1999
i am having problem with my esp and bas light i cant get it off at all does anyone know where i can find the switch i have a A160 THANKS
simba1 is offline
