FLASHING HEADLIGHTS - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-07-2004, 08:36 AM Thread Starter
Date registered: Jul 2004
FLASHING HEADLIGHTS
I have a 1993 190 E 2.6
My headlights are now intermittently flashing like it is some sort of warning signal. I can hear the click which seems to be controlling this from under the glove box in the passenger seat. What is it and how do I fix it? I am not sure the other drivers appreciate my lights blinking at them continusously as I drive. Please help.
shawnlaw is offline
post #2 of 6 (permalink) Old 07-07-2004, 09:48 AM
RE: FLASHING HEADLIGHTS
Sounds like a faulty relay to me.
samaki is offline
post #3 of 6 (permalink) Old 07-07-2004, 11:07 AM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
check your fuses but i also think its the flasher relay, fuse and relay locations
http://www.benzworld.org/publications/pub.asp?id=232
teky is offline
post #4 of 6 (permalink) Old 07-09-2004, 06:23 AM
Vehicle: 86 560sl 99 ml320
Same thing happened to my 89 190 2.6. It is a relay in the alarm system. The Alarm flasher is under the floorboard on the passenger side, that is why you hear it near the glovebox.
If you don't want to replace it, disable it by disconnecting, or you just close all doors, lock and then unlock the doors from the driver's side. You'll find that the flashing will occur if you are opening (unlocking) the car from the trunk or passenger door. You'll have to resign yourself to always unlocking the doors and trunk from the driver's side.
beguiledbybenz is offline
post #5 of 6 (permalink) Old 07-09-2004, 07:38 AM
teky's Avatar
Vehicle: chris
it could be but the alarm is normally connected to the flasher/indicators not the head lights unless its an after market alarm
teky is offline
post #6 of 6 (permalink) Old 07-12-2004, 12:58 AM
Storm's Avatar
Date registered: Jan 2004
I had the same problem with my R129 and its indicator, the problem finally fixed itself, the guys at the dealer just scratched their heads everytime I went there. I guess the heat had something to do with it.
Hopefully your problem is a simple relay or something similar.
Good Luck.[8D]
Storm is offline
