95 c280 helllllllllllp - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-21-2004, 04:38 PM Thread Starter
Date registered: Jun 2004
Send a message via AIM to marcanthony
my c280 was running ok just had a slight miss one in a while, so I change the plugs and wires noticed the 4 plug porcelain was burned so it was a good thing I did plugs. But now the car idles like crap! I have to drive it like a stick shift to keep it from surging!
I talked to some friends and the said some times the harness breaks on them so I checked and fix the wires to the coils and mass air flow sensor and air temp sensor! I also changed the fuel regulator! (It was leaking gas in the vacuum hose! I’m lost help me please! I like the car had it only 2 months drove it all in all 1 week! also had to put a new battery in also!
[V][:(!][?]
marcanthony is offline
post #2 of 2 (permalink) Old 06-21-2004, 05:46 PM
teky's Avatar
Vehicle: chris
RE: 95 c280 helllllllllllp
what voltage is the alternator giving out it should be 14.5 any higher will cause all sorts of problems less than 12 volts things start to fail
teky is offline
