AC versus dehumidified garage - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-14-2004, 03:38 PM Thread Starter
Date registered: Apr 2004
I'm looking to build a garage on rental property that I own and was wondering would using a dehumidifier suffice in lieu of air conditioning?
This would certainly be cheaper to operate.
Heat is not a problem here in Florida.
C.
atomsrock is offline
post #2 of 9 (permalink) Old 06-15-2004, 08:32 PM
Date registered: Dec 2003
RE: AC versus dehumidified garage
Why would you use either? Is this a classic and you're placing it in long term storage? If not, the garage will never be dehumidified because the garage door will never seal tight enough and the de-humidifier will simply work as hard as it can to reduce the amount of moisture. OTOH, if you're storing a classic and intend on sealing the garage, the dehumidifier would suffice.
E300POS is offline
post #3 of 9 (permalink) Old 06-15-2004, 08:43 PM Thread Starter
The structure would be constructed using concrete block and fully insulated. I would order the garage doors with insulation as I did on my home.
Yes, there would be leakage, but a very small percentage.
My main concern is rust due to the humidity which exceed 90% in the summer months.
C.
post #4 of 9 (permalink) Old 06-16-2004, 06:50 AM
amgbnz's Avatar
Date registered: Nov 2002
Vehicle: Widebody SEC
if you are just concerned about the car then use a carcoon for storage.
500SEC AMG Widebody
ML320
SLK230
1974 280 Coupe
those who want the best car in the world, drive a Mercedes-Benz
those who want the best Mercedes-Benz, drive a w126
MBCA executive board member
Mercedes-Benz Club of Canada - active member
MBFanatics.org moderator
amgbnz is offline
post #5 of 9 (permalink) Old 06-16-2004, 06:55 AM Thread Starter
That looks pretty interesting.
Does anybody have any experience with this product?
C.
post #6 of 9 (permalink) Old 06-16-2004, 07:50 AM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
How about getting separate AC unit for the garage ?
That should be a perfect fit - no duct work required and it's not a "window unit"
http://www.mrslim.com/UploadedFiles/Resource/MSeriesBroch2003.pdf
Kirill
Kirill is offline
post #7 of 9 (permalink) Old 06-16-2004, 05:24 PM
Date registered: Feb 2004
Send a message via Yahoo to lkirchner
I use this same type of bubble for my show cars. It keeps them clean. provides air movement and with the use of a desacant(sp?), they also help solve the humidity problem. I would definetly recommend their use.
lkirchner is offline
post #8 of 9 (permalink) Old 06-16-2004, 08:56 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
C,
How long have you been in Tampa? My cars and I have been here for a long time and none have ever rusted from the humidity. Your garage is a great idea but I’d save the expense – an MB in a garage in Tampa will last 100 years! If you feel the need to do more I would go for the “car bubble.� It’s good enough for show cars![:D]
jdc1244 is offline
post #9 of 9 (permalink) Old 06-16-2004, 09:27 PM Thread Starter
I've been here quite a while, I see that you're in Tampa too.
My problem is that I'm a pack rat, a three car garage that I can fit one car into, so, with my collection expanding, I'm just thinking ahead. I'm down to one motorcycle, so, things are clearing out.
Plus, I'm thinking of installing a lift either in my garage at home or in the new storage building. I like to do things correctly, a lift is a neccessary luxury for car restoration. Plus, with Clinton's China deals, $20k lifts and $2k air compressors can be had for $3k and $500 respectively. So, a nice garage is not out of the question.
email me at himsel@gte.net
C.
