COMAND / TV TUNER - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-10-2004, 03:04 AM Thread Starter
Date registered: Jun 2004
COMAND / TV TUNER
Hi,
Just taken delivery of SL500 2004. Is it possible to have the TV Tuner retro fitted? Can you simply buy a module and plug in?
Thanks for your help (if any)!!
stjohn1604 is offline
post #2 of 4 (permalink) Old 06-18-2004, 11:45 AM
Vehicle: 1999 ML430
RE: COMAND / TV TUNER
Not sure if this is what you want, but worked on my 04 TSX
www.nav-tv.com
When I die, I want to go out calm and peacefully like my grandfather did, not screaming and yelling like the passengers in his car.
GLisella is offline
post #3 of 4 (permalink) Old 06-18-2004, 08:32 PM
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
Because your car is a high spec model then it probably does have the cabling in place.
The place to fit it is next to the CD changer in the trunk.
As there are no instructions to retrofit the unit then I must assume the car is capable with just the insertion of the module.
miroj is offline
post #4 of 4 (permalink) Old 06-21-2004, 11:15 AM
Mark Cummins's Avatar
Vehicle: W211/W210 Estate /W209/W208
Quoted: 4 Post(s)
Please contact Steve at Mbenz.nl
Steve has done SEVERAL TVs in Mercedes With the Mercedes TV Tuner
The car is NOT prewired for the TV..BUT You Can Add the TV ..With all Mercedes Benz Parts
The Comand MUST Be reprogramed on the Blank Button
for the TV to work..It Will Work In Motion as well after the program is changed
The TV Tuner has a output for DVDs ....
Steve Does Installs here in the States..
Mark Cummins is offline
