OEM instructions for COMAND MY01 update 2.5 and 2.0 + recover after fail - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-26-2004, 07:20 AM Thread Starter
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
THIS IS FROM MB - FOR THE W220 when activating DVD player and TV tuner
Applies to COMAND 2.5 (I tried it on 2.0 and it works)
- update comand with CD
- apply same update TWICE or more (good to reset custom logo to OEM)
- recover from crash or fail
- prevent ICAN loops during install (checking CD error)
1 Switch off ignition and withdraw ignition key.
2 Switch on operating unit with ON touch switch and wait about
10 s until operating unit is correctly switched off.
3 Press keys * and # at the same time and hold and switch on
unit with ON switch. Wait until download screenis displayed,
then release keys.
4 Insert download CD. (In the case of CD version with automatic
CD eject, CD is ejected and must be inserted
once again).
5 Press the following keys to override an older or same version:
First of all RET alone, then 2 and 3 (and 9) at the same time.
6 For download with ICAN activity (if ICAN active, download
stops endlessly in the case of checking CD) press keys 1 and 3
at the same time (before start of download!)
7 Start download by selecting with start operating unit rotary
knob and press on rotary knob.
8 The download now runs automatically in two stages and takes
about 45 minutes in total.
9 Confirm final message with OK, remove download CD and
insert NAVI map CD, switch unit off and on with ON switch.
Procedure in the case of download problems
If the download does not continue running or takes significantly more
than 45 minutes:
Remove fuse F61 (for radio/sound/COMAND operating unit and
navigation) and insert again. This fuse is located in the right below the rear seat bench in the footwell (fuse and relay box below right rear seat). The fuse box is enclosed with a black rectangular plastic cover and can easily be opened without a tool. A drawing of the fuse assignment is provided at the vehicle tool kit in the trunk above the spare wheel. F61 is the 5th, counting from the middle of the vehicle, and the 14th, counting from the door (long row of fuses with a total of 18 fuse positions, not all of which are fitted).
After this, once again start the download process.
miroj is offline
post #2 of 4 (permalink) Old 02-01-2005, 07:44 PM
SKTeuber's Avatar
Date registered: Jan 2005
Vehicle: 2004 S600
Send a message via AIM to SKTeuber
RE: OEM instructions for COMAND MY01 update 2.5 and 2.0 + recover after fail
Miroj,
Thank you for the insight. I have read your information no several posts and you seem to have a lot of knowledge regarding a subject I am trying to learn about - TV Tuner.
I have a 2001 S500 that was brought over from Germany. The head unit has the button for the TV but says "No TV!" when pushed. I am trying to determine what parts I need (MB part numbers) for the unit and applicable cables. My boss will be going over to Germany next month and would get them from Mercedes from me if possible.
Could you provide me any insight? Also, is this boot sequence required? Where do I get the update CD?
While I am at it, how do I get my Nokia phone to work on the US network. The Nav system says "Telephone Initialising".
Thanks,
SKT
SKTeuber is offline
post #3 of 4 (permalink) Old 02-02-2005, 01:23 AM
sleepwalker's Avatar
Date registered: Apr 2004
Vehicle: Mazda 6
PLEASE be CAREFUL.
if you do it, don't cancel. make sure the battery is good. don't let anybody near the car nor open the door (voltage drop).
if you fail, the COMAND must be changed.
sleepwalker is offline
post #4 of 4 (permalink) Old 02-04-2005, 02:09 PM
Mark Cummins's Avatar
Vehicle: W211/W210 Estate /W209/W208
Quoted: 4 Post(s)
Contact Steve @mbenznl.com re the TV Tuner and all other parts needed for the Install..
Mark Cummins is offline
