300 sd oil pressure - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-04-2004, 12:01 PM Thread Starter
Date registered: Apr 2004
300 sd oil pressure
Oil pressure at guage in drive reads about half way up when moving with foot on accelerator max's out . Just wondering if that is normal I just got it a couple days ago its a 1983 when cold it stays maxed out but i have noticed a gradual lowering of pressure when it warms up . I dont understand the guage except to say its about at the 2 when sitting in drive idleing .
Critter is offline
post #2 of 2 (permalink) Old 04-04-2004, 02:07 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: 300 sd oil pressure
Those are measurements in bar pressure as opposed to psi – when cold with the engine at any speed the pressure should be at three bars. After the engine reaches operating temp, 80 to 85 degrees C, when the oil is warm and thins out, the pressure should be three bars under load and can drop to 1.75 to 2 bars when at idle. If the pressure drops to below one bar or does not peg out under load, have it checked by a mechanic. It could be as minor as a faulty gauge or as major as a bad oil pump.
Also, post in the w126 forum from now on and welcome.
jdc1244 is offline
