nearly killed when turbocharger failed - Page 3 - Mercedes-Benz Forum
post #21 of 25 (permalink) Old 07-12-2004, 07:35 PM
Date registered: Jun 2004
Vehicle: The "GENERAL"
Reply to n5160u...
"..BTW; I have always wondered about this:
Dodge uses the Cummins engine for their pickup and Ford buys their diesel from Navistar. The Cummins IMHO is the best engine for light duty trucks so why does Ford use Navistar when they own Cummins?..."
You have a good point...
Some of these business schemes perplex me...
Thanks again for the input...
"...Now when someone speaks of the [elusive?] runaway diesel concept I am better informed to speculate on failure analysis with them..."
Thanks very much you have been most enlightening...
89_190e_2.6 is offline
post #22 of 25 (permalink) Old 09-24-2005, 05:29 PM
Date registered: Sep 2005
RE: nearly killed when turbocharger failed
Runaway diesel engines are caused by the engine burning its own oil. usually caused by turbo oil seal failure or excessivly foul oil bath but ingestion of engine oil will burn like diesel fuel. Diesel engines run on compression generated by air and fuel> No spark just increase fuel and engine speed increases. When oil is sucked into the turbo and there are no ways to close off the air/block intake then the engine will run wide open(runaway) until it comes apart or runs out of oil. usually will explode first. So the best thing is to put it in neutral stop and get out. get away and let it happen cause your not going to stop it. Proper maintenance is the only way to prevent this.It happens in the marine industry occasionally. When it happens you just hope when the engine lets go parts exit up not down thru the hull causing the vessel to sink.
larzee58 is offline
post #23 of 25 (permalink) Old 09-24-2005, 07:16 PM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1988 560Sl
Quoted: 244 Post(s)
Having seen a number of diesels run-away, I can say it is a frightening experience. In each of the cases I was party too, I or someone with me simply smoothered the intake with shop rags (blocked the intake). If you can shut off the air, the combustion process will stop. Obviously, in a case as described above, theris no way to stop, get out, raise the hood, and shove a rag into the intake manifold; therefore, not much could have been done (except to throw the car into neutral and watch the fireworks). Old Detroit engines used to come equipped with a flapper on the intake manifold, which was spring-loaded to close when an emergency kill handle was pulled. This could easily be incorporated into an automobile, released by a selenoid, so I do not understand why it has not been the case. One fact is certain... Turbos eventually blow an oil seal, and begin passing oil into the intake. Usually, the bearings are shot by then, so a run-away is avoided by turbo failure. I had a Cat engine break a turbo shaft, which allowed oil to pass the seal. Thankfully, the broken shaft prevented the impeller from turning, so the engine was throttled to about 1700rpm (it did not blow apart, or run away). Strange; however, to seea large diesel engine run amuck (so much smoke the vehicle was shrouded...)
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #24 of 25 (permalink) Old 09-25-2005, 01:48 AM
560DBleu's Avatar
Date registered: Jul 2005
Vehicle: 87 560SEL SOLD: 95 SL600, 95/97 S600 coupe
Let me get this:
Turbo examples noted in diesel and non-diesel cars above.
What about the superchargers on the newer AMG Benzes?
560DBleu is offline
post #25 of 25 (permalink) Old 09-25-2005, 04:38 PM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
The runaway problem as described here only relates to diesels. On a gas engine all you have to do is turn off the ignition to stop the engine.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
