my new 2003, S55 won't hold a battery charge - Page 4 - Mercedes-Benz Forum
post #31 of 40 (permalink) Old 02-26-2004, 04:21 PM Thread Starter
Date registered: Feb 2004
RE: my new 2003, S55 won't hold a battery charge
Thank you so very much for posting. Yes, Park Place is a well-respected dealer and not too far from us. We purchased our car in Houston and that is quite a drive from East Texas. This forum and now you have helped both me and my husband from getting completely frustrated about our car. The day we got it back home we left for a three weeks in Mexico (weather is beautiful). If our car doesn't start after three weeks when we get home, we will jump start it and give it a good chance to start each time that we would drive it on a regular day at home. Thanks again for writing.
joeardis is offline
post #32 of 40 (permalink) Old 03-19-2004, 07:59 PM Thread Starter
[:)] Hello, I am the owner of this mercedes and the day after I got it back home from Park Place Motors in Dallas, I left it in the garage for 3 weeks and 2 days. It was not started during this time. First thing I did when I got home from Mexico was to see if my car would start and IT DID. That was a good test and I was so glad and I wrote Park Place and told them what a good job they did on my car. Again I thank the posters on this column for encouragement during a time when I wanted to give up. Thanks again.
joeardis is offline
post #33 of 40 (permalink) Old 03-22-2004, 02:10 AM
Date registered: Jan 2004
Glad to hear it's fixed [:)]
whereagles is offline
post #34 of 40 (permalink) Old 02-14-2007, 12:55 AM
Date registered: Feb 2007
i am having a battery drain problem. do you know what the dealer fixed in your car that corrected the battery drain problem?
jaan26 is offline
post #35 of 40 (permalink) Old 12-19-2008, 11:30 AM
ifari's Avatar
Date registered: Jan 2005
Vehicle: W215-CL500, W208-CLK320, W140-300SE
Quoted: 4 Post(s)
Recently bought a 2000 CL500 after researching on the boards here.
Excellent resource and they definitely aided in raising my confidence to purchase such a fine vehicle.
I haven't had it long and was told by the previous owner that it may need a battery, so I was prepared to buy one sooner than later. So a mth ago the battery was drained and I took it to the dealer for a new battery.
FastForward to a week ago...
After encountering the same problem of not having power a month after buying the new battery and having had the charging system checked by the dealer, my battery was drained again.
Took it dealer for another check and was told it needed an alternator.
WTF???... I said 'it was checked a mth ago'.
'Sorry, no good now' they said. 'It has a constant 90 ma draw'.
-- Here it gets interesting--
The 'stealer' missed my money--WHY... because he charged me an hour labour for his BS system check when the battery drained a 2nd time--this after charging me only 1/2 hr. labour to install the battery AND check the system when I bought the new battery a mth earlier.
(They wanted to get my car in ASAP....I wonder why...!?!)
BUT.... I wanted them to 'eat' the hr. labour (or at least a 1/2hr) towards the cost of the alternator work for the 2nd system check .
They refused!
'I'll think about' I said.
So, I sourced an alternator at NAPA ($160 less than MB) and called my independent mechanic who said $220 labour. Fair enough, I thought.
I took the car to my neighborhood mechanic this morning and had another charging system check before he started working on the car and he found everything OK.
Hmmm.
Battery was a bit low as I had charged it up myself the week prior, but, most importantly the alternator was charging!
Hmmmmm...
He also checked for a 'drain' and found one, at approx. 3 amps. I mentioned this thread and ejected the nav CD and voila the drain dropped to 0.90.
Total cost at my local garage....(drum roll please....) $44.
Fantastic!
Thanks to this thread I was saved spending $800 at the dealershit for a new(re-built) CL500 alternator w/labour because I told them I would think about it and am I glad I did.
Big Thanks to BenzWorld and the contributors of these threads!
ifari is offline
post #36 of 40 (permalink) Old 12-19-2008, 02:47 PM
Date registered: Feb 2003
Wow fantastic thread!!! Dealers should read this!
Measuring the draw on the battery makes sense. Isolating the source doesn't sound easy but once they find it - things like the fancy built in GPS system make you wonder?
I think MB should think outside the box when it comes to GPS stuff and simply give you a slick place to mount your own personal GPS choice in such a way that you can cover it or hide it when you leave the car parked. Now that idea would earn alot of interest. GPS units are quite personal devices now days given people load various data into them - you can carry them with you when you leave the car to help you locate a specific shop location on foot etc.
Wow thanks for posting the results great thread!
TW10 is offline
post #37 of 40 (permalink) Old 12-19-2008, 10:02 PM
V12StealthHunter's Avatar
Date registered: Jul 2007
Vehicle: w201,w124,w126
Quoted: 21 Post(s)
I'm over the moon if my battery lasts more than 24hrs (in the winter). At -30degC, your battery expectations are pretty low.
V12StealthHunter is offline
post #38 of 40 (permalink) Old 12-19-2008, 10:10 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
A random fault is difficult to identify but if there is an issue like with a CDC that does not let the car go to sleep or consuming power on its own, the standard workshop instructions for this should lead to the source of the issue directly. It should be obvious that a dead battery does not always mean that the battery is bad. Unfortunately a few workshops throw in new parts (and good parts out) and explain to the customer that "there appeared to be another faulty part in addition to the previously changed one".
Diesel Benz is offline
post #39 of 40 (permalink) Old 12-24-2008, 05:14 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 395 Post(s)
Navi CD caused battery drain
I picked up on this thread by chance today, and was reminded of a very similar electrical fault that I had about 1 year agp. My battery was running down every 2 or 3 days.
I asked at my M-B dealership for any suggestions as to what might be the cause, and one of the techs suggested that I eject my Navi CD while the car was parked and see if that made any difference. Well. it certainly did, and the battery drain problem was immediately gone.
Now I have learned from the 2004 saga above that this electrical drain might be caused by a COMAND unit navigation processor fault. Maybe. I'll look into the price of that.
Meanwhile I'll continue to eject the CD after using it on a trip.
keyhole is offline
post #40 of 40 (permalink) Old 12-26-2008, 05:58 PM
Mike Wevrick's Avatar
Date registered: Oct 2006
Vehicle: 2003 S500 4MATIC
The previous owner of my car had the same problem with it not starting after sitting for a few days and got the same runaround from the dealer. Finally got it fixed but it was like pulling teeth ...
I grew up in Ottawa 30+ years ago and don't remember this ever being a problem. A good modern battery should be fine even in extreme cold.
"Mercedes: Expensive and Built to Stay That Way"
Mike Wevrick is offline
