why MB uses SOHC??? - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 02-08-2004, 06:56 AM Thread Starter
musso's Avatar
Date registered: Jan 2003
Vehicle: Mercedes Musso TD
why MB uses SOHC???
i was a mercedes fan.. yah.. i really love the mercedes S, it's still my dream car,.. i was used to be with hondas and there performance cars uses DOCH instead of SOCH, ya, the performance world is turning to DOHC, but why high end mercedes uses goddamn SOHC??
I'm a benzophile
musso is offline
post #2 of 21 (permalink) Old 02-08-2004, 09:17 AM
BenzWorld W124 Host
Tubs300E's Avatar
Date registered: May 2003
Vehicle: 1993 300E 3.2L 24V
RE: why MB uses SOHC???
My 1993 300E uses D0HC. I couldn't really tell you why. I mean, you could also ask why is the Corvette a pushrod? It's all about the application in which the engine is going I think. Oh and cost too, don't ever forget about the money factor.
-Tubs
W124 Forum Host
1993 Mercedes-Benz 300E Arctic White over Palamino Leather
W124.032 Chassis M104.992 24V Engine
217 Horsepower @5500RPM
229lbs-ft Torque @3750RPM
Aftermarket Modifications
-TYC Euro-Spec Headlamps
-DEPO Clear turn signal indicators
-Kenwood KDC-217S CD Player AM/FM Tuner Headunit
-Chrome Exhaust Tips
-Auxiliary fog lights and driving lights
-Tinted windows: 22.7% on the back 5 and 33% on the front 2
Tubs300E is offline
post #3 of 21 (permalink) Old 02-08-2004, 07:14 PM
Date registered: Dec 2003
Vehicle: '05 330i ZHP
You got it right, Tubs, money, the newer engines are crap. You see, they make good quality cars and engines for a while, (eg, W140 S600) then the costomers complain about high prices, so they lose quality(W220) and the price goes down again. Then, they complain about quality, and the cycle repeats. The new V6 that they only just released is showing a climb in quality again, so thats good.
E V12 Nerd is offline
post #4 of 21 (permalink) Old 02-13-2004, 12:10 PM
texnteg's Avatar
Date registered: Sep 2002
Vehicle: 2002 E320W4
Send a message via AIM to texnteg
SOHC gives you better low-end response and torque. the MB is 3-valve btw, not 2-valve. it is a very efficient system. DOHC is only neccessary on a small-displacement motor. notice how honda's V6(excluding the NSX) uses SOHC. it wouldn't give MB that much more power to have DOHC when they have the 3-valve system. a MB is about torque and pulling power, not about high-revs and no torque(like my integra and old Type-R(RIP[V])).
plus, less rotating mass helps make the motor more compact and lighter.
"Steel Stallions: Rollin' Hard, Rollin' Fast, Rollin' By" Robert Earl Keen
1990 Honda Integra
1989 M-B 190DT EvoI<< sold
2002 M-B E320 4matic
searching for a 300E 4matic
texnteg is offline
post #5 of 21 (permalink) Old 02-14-2004, 02:39 PM
Vehicle: 2004 E55-1970 280SEC
MB switched to SOHC because of the low end torque and better emmission of the 3 valve twin spark V engine design. But MB is also transitioning to a brand new direct inject DOHC 4 valve engine starting with the SLK350. They will eventually replace all their V's with this congfiguration because they make V6 and V8s on the same line. It should get better gas milage and even better emmissions because of the direct inject is very percise.
2009 C63 AMG Silver/Charcoal
1970 280SE Low Grill Coupe 2.8 Silver/Red
Past
1999 SLK230/Sport
2001 SLK32 AMG
2004 E55 AMG
Norb is offline
post #6 of 21 (permalink) Old 02-14-2004, 04:54 PM
ae86pwr's Avatar
Date registered: Nov 2003
Vehicle: 98 ML320 / 06 S2000 / 12 E350 BTC
Send a message via AIM to ae86pwr Send a message via MSN to ae86pwr
less moving parts makes your mechanic happier
ae86pwr is offline
post #7 of 21 (permalink) Old 02-15-2004, 01:25 AM
JQ
JQ's Avatar
Vehicle: E430T + 300SL (W107)
As stated previously MB uses a SOHC 3 valve design to accommodate twin sparkplugs with a potential more efficient burning and hence better fuel economy and less exhausts. Problem is however that the limited valve area makes it more difficult to achieve high power-to-displacement ratios, and the next generation engines will use 4 valves per cylinder and higher output power.
_________________
/ Joakim Quensel
2000 E430T & 1989 300SL
JQ is offline
post #8 of 21 (permalink) Old 02-16-2004, 11:14 AM
Mark08859's Avatar
Date registered: Jul 2003
Tubs300E - 2/8/2004 11:17 AM
-Tubs
In addition to economics, GM uses pushrod engines to accommodate itself to the American style of driving. With no Autobahns or Autostradas permitting drivers to reach the upper limits of their engine's capabilities, GM gears itself to off-the-line acceleration.
The so-called stop light race. Believe it or not, for this type of driving, a pushrod engine excels over more modern DOHC and SOHC applications. Of course, one might be at a disadvantage when going up against a modern engine where you can do a long distance haul.
'08 C300 Sport/Barolo Red/Gray-Black Leather/6 SP/AMG Wheels/iPod/P2/MultiMedia/Tele Aid
'09 Pasion Coupe/Gray Metallic/Black Tridion/Comfort Package/Solid Roof/Premium Sound/Fog Lights/Clock-Tach/Anti-Theft/Navigation/Bluetooth
Mark08859 is offline
post #9 of 21 (permalink) Old 02-16-2004, 04:08 PM
TonyD's Avatar
Vehicle: 1982 300SD
Send a message via Yahoo to TonyD
Before anybody assumes DOHC and 4 valves per cylinder is somehow "New technology," remember that the first engines that used it were built around 1911 or 1912. Harley Davidson racing motorcycles were DOHC 4-valve design before the First World War.
TonyD is offline
post #10 of 21 (permalink) Old 02-16-2004, 06:25 PM
Date registered: Feb 2004
Send a message via AIM to Star Tech
MB is releasing a new family of engines over the next couple of model years. They are all going to be DOHC.
Star Tech is offline
