Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 01-16-2004, 09:52 PM   #1 (permalink)
Date registered: Nov 2003
Vehicle: 500 SEC
500SEC mystery problem?
Heres the symptoms:
Feels like the handbrake is on, or it's towing a 5 ton caravan , really slow to take off.
Feels like the brakes are on, but as soon as I knock it into neutral, it coasts easy.
Economy meter stays half way up, as if accelerater was half way down, even when backing off & cruising.
Not running hot.
If I give it full throttle, it goes average, whereas before it would take off like a rocket.
Suspect something in the trans, but is supposed to be a recon (I only recently bought this car, and has been running great)
any clues?
thanks in advance
Mac
byronbenz is offline   Reply With Quote
Old 01-17-2004, 08:14 AM   #2 (permalink)
Date registered: Dec 2003
RE: 500SEC mystery problem?
You're more likely to get a prompt and accurate answer if you re-post this in the 126, 140, or other appropriate forum.
E300POS is offline   Reply With Quote
