Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 01-10-2004, 09:56 PM   #1 (permalink)
Date registered: Jan 2004
300E engine misfiring in very cold weather
My 1986 300E has always run like a dream until zero temperatures hit this week in Maine. The engine all of a sudden is misfiring on what seems like 2-3 cylinders. I changed the 6 Bosch plugs, but this was not the solution. I removed the distributor cap and all 6 contact points had "green corrosion" on them. I cleaned each contact as best that I could with emery paper, but the problem is really not that much better. Could it be my ignition wires? What is the best way that I can test them on a Sunday ? I am going to order a new rotor and distributor cap on Monday (the old one definitely needs to be replaced). I bought this car with 93K miles and it now has 171K miles. I've got a feeling that the rotor , distributor cap and ignition wires are all original equipment. Could the severe cold weather change have caused the ignition wires to crack? I would appreciate any help and suggestons.
Thanks,
Peter[:(]
Maineiac is offline   Reply With Quote
Old 01-10-2004, 11:41 PM   #2 (permalink)
Where's my auto-leveling?
AndyFracica's Avatar
Date registered: Sep 2003
Vehicle: '06 ML350 '03 E320
RE: 300E engine misfiring in very cold weather
Maineiac - 1/10/2004 10:56 PM
Thanks,
Peter[:(]
It could be that the electronic ignition module is failing in the cold and you are not getting a hot enough spart on all cylinders. Just a thought.
Andy
2006 ML350
723 - Pewter, 104 - Macadamia Interior, H04 - Brown Birds Eye Maple Wood, 167 Standard Non-Sport Pkg, 317 Comfort Pkg, 318 - Trim Package, 319 - Lighting Package, 320 - Entertainment Pkg, 324 - Sunroof Pkg, 580 - Std. Climate Control, 873 - Heated Front Seats, 890 - Power Liftgate, Navigation System, iPod interface kit
Modifications:
Added: Chrome Door handle cups, MB Twin Spoke 5-Spoke 18" wheels and tires
AndyFracica is offline   Reply With Quote
