ML63 2008 code0732 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-28-2017, 10:09 AM Thread Starter
Date registered: Jul 2012
Vehicle: 2005 CLK320, 2005 C230
Quoted: 2 Post(s)
ML63 2008 code0732
Hello all,
I just purchased a 2008 ML63 that was a local Oregon vehicle with a excellent dealer service history and 95K miles. It is in amazing condition and runs and drives well. two weeks ago it was serviced and had no issues. A check engine light came on and it is Fault 0732. Now the dealer is recommending a $9,000.00 service replacing the camshafts and related parts due to low compression. is this normal for the 6.3? Just wondering if anyone else has experienced this issue. I attached the document from the dealer.
allwheeldrive is offline
post #2 of 8 (permalink) Old 01-28-2017, 10:17 AM
Date registered: Jan 2017
Quoted: 4 Post(s)
i think you dealer is full of crap to be honest with you. the camshaft wouldn't affect compression in the engine. the valve would have to be hung open or cylinder wear of some sort. Another question is why are they replacing the head boths if they arent removing the heads. sounds like a waste of money there to me. i would definetly get a second opinion on the vehicle before spending that kind of money on it. i am a mercedes benz technician and will look linto the code and see what i can find out.
buggwuggy2017 is offline
post #3 of 8 (permalink) Old 01-28-2017, 10:23 AM Thread Starter
Quoted: 2 Post(s)
Thanks,
I was doing a little research and found a class action lawsuit about this issue. The camshafts were to soft and had premature failure. I will take it to a independent shop and get another opinion. The "action plan" was for the previous owner. Something smells fishy I'll admit. Have you ever done this job?
post #4 of 8 (permalink) Old 01-28-2017, 10:27 AM
Quoted: 4 Post(s)
Originally Posted by allwheeldrive View Post
Thanks,
i looked up the cault code P0732 and found this link
https://www.engine-codes.com/p0732_mercedes-benz.html
i have never heard of the lawsuit or that problem. i know that the Balance shafts had problems in he v6 models and the timing gear in some of the v8 models but never heard or seen anything about the cams failing
post #5 of 8 (permalink) Old 01-28-2017, 10:49 AM Thread Starter
Quoted: 2 Post(s)
I hope it isn't serious. What software do you use at work? I own a shop and we use a snapon Verus and shut track but I don't have access to the good stuff.
post #6 of 8 (permalink) Old 01-28-2017, 10:51 AM Thread Starter
Quoted: 2 Post(s)
post #7 of 8 (permalink) Old 01-28-2017, 10:53 AM
Quoted: 4 Post(s)
i have access to the original mercedes benz software that the dealer has. ther is a company out of LAsVEgas that offers it
post #8 of 8 (permalink) Old 04-30-2017, 09:56 AM
Date registered: Jul 2005
156 engine failures?
I have owned our 2007 ML63 AMG for three years. It still is in mint condition and has less than 133,000 miles on it. So far only an idler pulley and the engine coolant thermostat have failed. My wife and I treat it with 'kids gloves' and drive it with medium (89 octane) gasoline, never exceeding 2,500 engine RPM. As a result we consistently average 16 mpg by the tank full. The failures discussed above must be caused when the car is driven to its design limits. Otherwise, the ML63 AMG is one of the safest SUVs on the road. Last year I also bought a 2012 S63 AMG with a 100,000 miles on it. What a car! It has a 10-1 compression ratio, does 60 mph at 1,500 RPM and 80 at 2,000 and averages 20 mpg. You may laugh, but keeping accurate track of your fuel consumption is a great indicator of engine health. :-)
Friedolin is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > General AMG
