» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz AMG Forums > General AMG
Old 08-07-2009, 08:53 PM   #1 (permalink)
Date registered: Aug 2009
Question What model Mercs have supercharged V8s?
G'day folks,
Appreciate one of you Merc genius' listing the post 2000 year models fitted with a supercharged 5 or 5.5 litre V8.
I think some of these jiggers are the E55 and the CL but
a) are there others and
b) does Merc produce a V8 supercharged CLK.
I bet this has been asked a hundred times but I cannot find the threads.
Cheers,
Allen.
Mountainbenz is offline   Reply With Quote
Old 08-11-2009, 12:21 AM   #2 (permalink)
Mizx's Avatar
Date registered: May 2004
Vehicle: 450, 350 & 280 SLC (W107), 280TE (W123), C36 AMG (W202), Brabus B6S (W210)
First one was R230 SL55 AMG, then S55 AMG and CL55 AMG. No superchargers earlier than ~2003.
Mizx is offline   Reply With Quote
Old 08-12-2009, 04:30 PM   #3 (permalink)
Date registered: Jul 2008
Vehicle: 2004 Mercedes-Benz S55 ///AMG, 2006 Mercedes-Benz E350
Mizx is correct. The 55 engine is a V8 Kompressor engine and started in 2003 and ended in 2006. This engine was used in SLK (detuned version), E, S and CL Class cars. Also G55 has the same engine.
Klaus9000 is offline   Reply With Quote
Old 08-17-2009, 01:01 PM   #4 (permalink)
Date registered: Jun 2005
all the AMG cars from 2003-2006 were supercharger except the SLK and CLK
but they all run the same 5.5 liter engine
hami is offline   Reply With Quote
Old 08-17-2009, 01:02 PM   #5 (permalink)
only the Kleemann type of the 03-06 CLKs had superchargers on them and they were made by Kleemann not AMG
Old 08-23-2009, 08:29 PM   #6 (permalink)
The supercharged engine wasn't stopped in 2006. You can order a 2010 G55 with a 500+HP supercharged 5.5.
NoPaint is offline   Reply With Quote
Old 08-25-2009, 02:30 AM   #7 (permalink)
Many thanks to you all for the interesting answers.
Any further info would be also welcome.
Cheers,
Allen.
Old 08-25-2009, 09:39 AM   #8 (permalink)
asianml's Avatar
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
G'day folks,
Cheers,
Allen.
W211 E, W215 CL, R230 SL, W220 S, SLR McLaren, W463 G, and the C219 CLS use(d) the 5.5L Kompressor V8. The W203 C, W163 ML, W209 CLK, and R171 SLK used the N/A 5.5L V8. The only models still available with the Kompressor are the G and SLR McLaren.
There never was the Kompressor AMG CLK. The only AMG engines in the CLK have been the N/A 5.5L V8 and the N/A 6.3L V8.
asianml is offline   Reply With Quote
Are the V8s underpowered? randian General Mercedes-Benz 16 10-09-2008 05:53 PM
Older iron block V8s (W116) vs W126 aluminum merouby W126 S,SE,SEC,SEL,SD,SDL Class 3 04-06-2004 07:31 PM
V8s and LPG heckflosse R/C107 SL/SLC Class 5 09-19-2003 01:17 PM
V8s - Unleaded and LPG heckflosse W126 S,SE,SEC,SEL,SD,SDL Class 0 09-18-2003 12:33 AM
direct injection v6/v8s? what are the specs?... cgeorge430 W163 M-Class 4 08-04-2002 11:29 PM
