Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > General AMG
Old 03-08-2008, 12:12 PM   #1 (permalink)
Date registered: Mar 2008
Unhappy CIS Injection problem
At present I'm a Mercedes owner wanna-be and in reading the Benzworld forums have found Mercedes "techies" very informed regarding CIS injection which is nearly identical to that on my '78 Volvo, if I may so assuming as to use the word! Here is my story to date:
Ignition system checks out; Timing belt has not jumped; Fuel presures are within limits; Fuel pump output is good (measured at return line under hood); Relays seem to be working properly;
When engine cranks current shows up at Aux air valve, Cold start injector, Warm up reg., and Lamda loop frequency valve. (Volvo's O2 sensing system).
When running pump and lifting air sensor plate injectors spray but the strange thing is that when the engine cranks injectors don't spray. This seems to be the crux of the no start. Does this indicate that there isn't vacuum enough to lift the plate??? Compression is good, manifold gasket is new and I've plugged all orifices in the intake manifold. I've also noticed a small amount of gas collecting in bottom of sensor plate housing. This seems abnormal.
I'm hoping that one of you out there is the Lone Ranger with that silver bullet I'm looking for. I'm totally out of ideas.
demar is offline   Reply With Quote
cis-e problem feras R129 SL Class 4 07-01-2006 11:26 AM
CIS-Altitude Sensor problem Robert-Stonjek W126 S,SE,SEC,SEL,SD,SDL Class 2 03-20-2006 01:33 AM
metal fuel line CIS fuel injection 79 280se w116 rfitts46 W116 S, SE, SEL, SD Class 0 01-28-2006 03:37 PM
450 Injection system..switching to CIS?? bc2885 Vintage Mercedes-Benz 3 07-08-2005 09:05 AM
Urgent Help Needed for CIS Problem SLR Technician W126 S,SE,SEC,SEL,SD,SDL Class 5 12-09-2004 02:43 PM
