Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 10-11-2003, 10:24 AM   #1 (permalink)
petermerle's Avatar
Date registered: Nov 2002
Vehicle: 1982 300GD *2
How to remove gutter trip surround
How does one remove the gutter surround with damaging it?? I am busy stripping the vehicle in order to respray but am stuck with this item. Has anyone done this sucessfully?
PEter Merle
http://autos.groups.yahoo.com/group/SAGW/
W460.332 300GD *2
W123.130 300D
W124.130 300D
W120.110 180D
petermerle is offline   Reply With Quote
Old 10-11-2003, 11:03 AM   #2 (permalink)
~BANNED~
DUTCH's Avatar
Vehicle: 2000 G500 NMLE & 2007 ML320 CDI
Re: How to remove gutter trip surround
PEter Merle
It's held in place with double sided tape. I think you're probably out of luck.
DUTCH is offline   Reply With Quote
Old 10-11-2003, 11:40 AM   #3 (permalink)
petermerle's Avatar
Re: Re: How to remove gutter trip surround
Mine us different - its an aluminium extrustion sthat slides over the edge between roof and side panel. No tape or glue. There is one rivet at the front and I think one drives it out to the front - very strickey
Peter Merle
Old 10-11-2003, 03:26 PM   #4 (permalink)
Dai
Dai's Avatar
Date registered: Feb 2003
Vehicle: 85 300GD 83 300TD
Gutter mouldings...
I drilled out the rivets and then removed those sections. There are clips that are spring loaded over the seams that are removed by prying them carefully off from the bottom. After the clips are off the rear section slides out to the side. The side sections can be twisted gently from the bottom up and off. There is a goo that is a body seam putty stuff that is behind the moulding that might be what you are fighting. Try warming up the moulding with a hair dryer or heater to soften it. Best of luck,
-Dai
Dai is offline   Reply With Quote
Old 10-12-2003, 01:04 AM   #5 (permalink)
Greeney's Avatar
Date registered: Jun 2003
Vehicle: 300GD 5 dr 1987
Send a message via MSN to Greeney
Gutter
I dont have my rear trim as someone decided to remove it and damaged it in the process. so I presume they are not the easiest of things to remove.
I have yet to find a new one although I havent tried MB Dealer yet
Nicholas Greene
Criminal Psychologist
Neuvic Entier
FRANCE
Greeney is offline   Reply With Quote
Old 10-12-2003, 05:23 AM   #6 (permalink)
~BANNED~
DUTCH's Avatar
Re: Gutter
It's the same on all models - 460, 461 & 463; and it's readily available.
Old 10-12-2003, 11:11 AM   #7 (permalink)
Dai
Dai's Avatar
Rear gutter trim..
Hi Greeney, the rear trim was easy to remove on my truck. Once the spring clips that hide the joints are off they slide off the gutter to the side. (From the center of the rear of the truck out, sliding it along the gutter.) The side mouldings clip over the gutter from the top and don't slide along easily. If the rears are removed like the sides I think they would be damaged easily because of the curve built into the trim. My truck had a couple of replacements when I got it that were chromed and my trim is all black so I removed them to paint them. Best of luck finding replacements,
-Dai
