Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 08-04-2003, 09:24 AM   #1 (permalink)
Kuzuki's Avatar
Date registered: Jul 2003
Vehicle: 1986 280 GE lwb
Send a message via ICQ to Kuzuki Send a message via MSN to Kuzuki
Fuel injection
Have problems with the fuel injection sistem. 1986 GE280 Mechanic says it's the fuel distribution unit. Can this be rebuilt-recalibrated or do i have to get a new one?
Thanks
Mike
Mike
280GE
Kuzuki is offline   Reply With Quote
Old 08-04-2003, 10:36 AM   #2 (permalink)
Hipine's Avatar
Date registered: Nov 2002
Vehicle: 1980 LWB 280GE
It depends
What's the problem? My truck has 300,000 miles on the original fuel distributor. I just don't ever hear of these "wearing out". If you have more informaiton about specific symptoms maybe we can direct you to another potential culprit. Has the full fuel system pressure test come back with all parameters within acceptable ranges? That's the first thing that must be done. System pressure, control pressure, warm-up timing, etc.
Let us know.
-Dave G.
Hipine is offline   Reply With Quote
Old 08-04-2003, 11:21 AM   #3 (permalink)
Kuzuki's Avatar
The engine runs smooth at idle but sometimes when to accelerating it runs rough and then...
The engine runs smooth at idle but sometimes when to accelerating it runs rough and then smoothes out. Will change fuel filter this weekend and take it to another mechanic to see what he comes up with...
thanks,
Mike
Old 08-04-2003, 02:29 PM   #4 (permalink)
Hipine's Avatar
Hmmm....
Have them check all the fuel pressures, including WHILE it's acting up if at all possible. Also an injector spray pattern test, and air meter baffle plate alignment might be in order. Just some thoughts. See what the second opinion turns up.
-Dave G.
Old 08-04-2003, 04:05 PM   #5 (permalink)
Vehicle: 2000 G500
Recommend either a large inport concern or a Benz dealer. Ask for a mechanic that has a l...
Recommend either a large inport concern or a Benz dealer. Ask for a mechanic that has a lot of experience with Continuous Injection Systems (CIS).
I'm with Hipine. It's very rare for the fuel distributor to go bad. Most likely bad culprits in the past for me have been:
- leaky cold start injector
- vacuum leak around the injector seal
- clogged or worn out injectors
- dirty area around the throttle plate (causes restriction of the plate movement)
S,
J.R.
2000 G500 LWB Obsedian Black
2005 Toyota Tacoma 4.0 liter
1993 240DL Anthracite
1986 280GE LWB Anthracite (Sold, and part of me wishes I hadn't)
1980 450SEL retired after 15 years of faithful service
JRBrown is offline   Reply With Quote
Old 08-05-2003, 02:39 PM   #6 (permalink)
Date registered: Aug 2003
Vehicle: 280GE
Injection
I had the same problem with my 85 280GE. I cleaned the air plate as suggested and then noticed that the throttle push rod bush (on bulk head beside rocker cover) was worn. The throttle actuating arm was moving slightly causing exactly the same symptoms.
May be worth a look.
mttbtt is offline   Reply With Quote
Old 08-05-2003, 03:04 PM   #7 (permalink)
Kuzuki's Avatar
thanks for the info will check it out.... Mike...
Mike
Old 08-06-2003, 04:19 PM   #8 (permalink)
Vehicle: 280GE
injector
I forgot to add that i adjusted the linkage as well to make sure that the nylon bush that is located in the "J" on the throttle mechanism (beside fuel distributor) is fully into the toe of the "J" when cold.
This can be done by making an adjustment to the push rod that comes from the bulk head bush.
About 1" up from the bush is a nut and bolt holding together 2 small flanges. Undo and you will find that one of the flanges is slotted. I moved it up the slot until the nylon bush was in the toe of the J and hey presto seamless acceleration. Prior to this it was about 1/2 wat between the toe and the heel of the "J"
Good luck
M
