» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 06-11-2003, 04:53 AM   #1 (permalink)
Vehicle: 1984 GE280
Found the bad bearing in the tranfer case!
As I was tearing down I saw nothing that was making
the aluminum particles and the metal particles.
Well last night I finshed taking it a part the
primary shaft that has the gear selector onit
has a needle bearing on it and its cage is aluminum
it was bad but I caught it just in time no other damage was done So Dave you were correct in where you said it would be !!thanks
Oh so if you change your transfercase fluid and there is silver in the drain bucket bearing time!!
Thanks for the help everyone
I will post the out come after I finsh doing bearings![:)]
Gerald A is offline   Reply With Quote
Old 06-11-2003, 07:33 AM   #2 (permalink)
Hipine's Avatar
Date registered: Nov 2002
Vehicle: 1980 LWB 280GE
Nice job Ger!
Way to stick with it. You can probably get away with replacing just that bearing. No additional wear on the surfaces teh rollers ride on? That would be most excellent.
-Dave G.
Hipine is offline   Reply With Quote
Old 06-11-2003, 08:03 AM   #3 (permalink)
Thomas.Schumacher's Avatar
Date registered: Dec 2002
Vehicle: 1985 300GD LWB 5 Speed
Gerald - What type of lub were you using, etc?
Any other thoughts as to what might have caused the failed bearing? Lub type, weight, total mileage, type of use, out of balance drive line, etc.
Thanks - Good luck on the assembly side of things. Keep us posted.
Thomas
Thomas.Schumacher is offline   Reply With Quote
Old 06-11-2003, 05:56 PM   #4 (permalink)
Vehicle: 1984 GE280
Re: Gerald - What type of lub were you using, etc?
I was using Castrol as percribe by Europa Aka Gwagen USA Blend Synthetic This time I want to know what you guys use?????
Old 06-16-2003, 09:26 AM   #5 (permalink)
Amsoil 85-90 snythetic seem to run cool and quiet. No leaks so far.
I am also using Amsoil in the axles.
