Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 04-27-2003, 02:51 AM   #1 (permalink)
Date registered: Jan 2003
It say's clock clock clock when I'm turning
Hi,
When I'm turning I get a sound that sounds clock clock clock from the driver side front wheel.
I'm driving in 2x4 not in 4x4 mode and when I'm turning
the car make that clock sound and the speed drops like a
breaking effect.
1986 LWB GE Automatic
[:(] Andreas
andreas is offline   Reply With Quote
Old 04-27-2003, 04:22 AM   #2 (permalink)
~BANNED~
DUTCH's Avatar
Vehicle: 2000 G500 NMLE & 2007 ML320 CDI
CV Joints
Hi,
breaking effect.
[:(] Andreas
and, possibly, the front wheel bearings need to be replaced. My guess.
DUTCH is offline   Reply With Quote
Old 05-01-2003, 06:54 PM   #3 (permalink)
BENZITEAM's Avatar
Date registered: Apr 2003
Vehicle: 230G
had this problem
Make sure u re not running in 4wheel drieve, even though the lever is on 2wheel drive position, it could have stayed 4 High, in anyways CV joints are a bit damaged, i have this sound from 4 years till today, CV joints are worn but maybe needs some grease
The braking effect on asphalt is normal, u re running in 4high (pull the lever to 4high then to 2wd then engage Reverse, go back for some meters, the braking effect will Go for sure. and u should not hear the clock noise again on asphalt unless u engage 4high.
Tell me if u still have this problem
What have we done, MOGGY what have we done!!
BENZITEAM is offline   Reply With Quote
