Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 03-27-2003, 11:35 PM   #1 (permalink)
Iwan's Avatar
Vehicle: CLS 55...
Noisy suspension
I have a '85 280GE and there has been recently clunking noise from the rear when I turn or go over a speed bump. It sounds as its coming from the rear axle or suspension, could it be worn bushings on the suspension arms ? And my rear springs often bottom out even without a full load. Do they need to be replaced ? Thanks for any inputs.
___________________
'05 CLS 55
'85 280 GE (a classic !)
'07 LR3 TDV6 HSE
'07 BMW R 1200 GS
Iwan is offline   Reply With Quote
Old 03-28-2003, 12:27 AM   #2 (permalink)
Thomas.Schumacher's Avatar
Date registered: Dec 2002
Vehicle: 1985 300GD LWB 5 Speed
Suspension noise
Iwan,
Are you able to create the noise by pushing downward on the rear bumper? Or by rocking the body side to side? You might be able to isolate the source of the noise.
This could be shocks or worn or broken shock mounts. Also, the bushings in the cross-suspension arms (I call them Panhard rods but I know they have an official name) create this noise when going over things like speed bumps. When you are bottoming-out your springs how fast and on what kind of surface are you driving.
Oh, and what year is your G. The information on your registery does not mention year or body style of your vehicle.
There is also a spring diagnostic proceedure on the maintenance manual CD, showing measurements between reference points of the frame and axle, for the front and rear. This compares the heigt of each wheel well to the others, and suggests an exact standard or specification for suspension position in mm's. I am certain other on this board have other methods of determining shot-spring diagnosis. Do you have Harald Pietschmann's manual on CD, or similar workshop manual?
Good luck.
Thomas
Thomas.Schumacher is offline   Reply With Quote
Old 03-30-2003, 08:20 PM   #3 (permalink)
Iwan's Avatar
Vehicle: CLS 55...
Re: Suspension noise
Iwan,
The noise is occasionally and it didn't make noises this morning. The bottoming out occurs while normal driving (40-50km/h) and on normal surfaces (not off road). My guess is bushings as my shocks were replaced a while ago.
I have a 1985 280GE SWB.
Unfortunaltey I don't have any of these manuals or CD, but they look very helpful. Could let me know how could I get one of them (either CD or manual) ?
Good luck.
Old 03-30-2003, 10:59 PM   #4 (permalink)
79percent's Avatar
Date registered: Oct 2002
Vehicle: W463, 300GE
Send a message via MSN to 79percent
Hello Iwan, And the message is... try to clean the post where the springs sits on. So...
Hello Iwan,
try to clean the post where the springs sits on. Sometime there is rust or even mud in between.
Check your shock absorbers !
Mit freundlichen GrĂ¼ssen
Klaus
Klaus, formerly known as 300GE
http://www.gwagen.de
79percent is offline   Reply With Quote
