Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 08-05-2002, 06:46 AM   #1 (permalink)
NickT
Posts: n/a
A clunk from the rear ?!
Took the G offroad on sunday ,lots of axle twisters in the mud . Had the rear locker in and out all the time <br> The problem is I developed a loud click / clunk from the rear other than the spring reseating what else could it be ?<br> I drove for a hour in 2wd home from the site and it was fine so I do not belive it is the rear dif ( thank goodness )<br> <br> Is there anything else I should check ?<br> <br> Tks Nick
Old 08-05-2002, 04:03 PM   #2 (permalink)
mserpe
Posts: n/a
Re: A clunk from the rear ?!
when does it happen?<br> <br> when you are rolling?<br> <br> going over something?<br> <br> When you engage a drive gear, or shift?<br> <br> <br> when you step on the gas hard?<br> <br> Check your u-joints on the driveshaft.<br> Also jack up the rear axle and look for excess play in the diff.<br> <br> -mserpe
Old 08-05-2002, 05:58 PM   #3 (permalink)
Thomas Schumacher
Posts: n/a
The Panhard (spelling) rod bushings were dryed out in my G, and made noises like this whenever I went over uneven ground. They move a great deal as the axles rise and fall, and the body moves side to side. Once I replaced the old bushings, the noise was gone. Have you attempted to create the noise while parked, by pushing up on the body?<br> <br> I agree with mserpe that if could be driveline related issue as well. <br> <br>
Old 08-06-2002, 05:43 AM   #4 (permalink)
NickT
Posts: n/a
Thanks for the info , How do I check for play on the diff ?<br> The noise only came about when I was on rough terain since then it has been fine .<br> I am just begining to get a BAD feeling about this .<br> <br> Tks for the feed back guys <br> <br> Nick
Old 08-06-2002, 09:19 AM   #5 (permalink)
Pete
Posts: n/a
It could be as simple as an inproperly closed rear door that needs adjustment.
