Lokking to put different wheels on an 86 280, and the local shops are having a hell of a time. 9 out of 10 say I'll have to get custom ones made (1k+ each!), but 1 guy said all Mercedes have the same bolt pattern, a '5 on 112'. He says any wheel that fit any Mercedes should fit a G. Does that sound right? Can anyone recommend a wheel co that can fit a G?
Since mine is an 86, will a more recent set of rims still fit? i.e. Ebay item #1845587248 for instance? I'd hate to drop a bunch of cash on G-rims that don't fit. Thanks a lot for the help everybody-
Also, I've had adapters made up so I can use 'off-the-shelf' 5x5.5' wheels instead. Also, if you fit larger tires it is much easier to man handle a wheel onto 5 studs then to try and line up five holes and screw in one of the lug bolts! They were like $75/ea I think.
$1K for custom wheels? I don't think you need to go to that extreme. I had a set of wheel custom drilled for my G500, at a cost of $150 each wheel (wheel + drilling).<br>
<br>
The G500 is turning out to be the cheapest Mercedes to customize!<br>
<br>
Here's a pic from the evoworks show last weekend. Sorry you can't see the wheels really, but you can tell the tires have been changed.<br>
<br>
-s-<br>
<br>
