Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 11-14-2001, 02:44 PM   #1 (permalink)
Jim Laurel
Posts: n/a
G-Wagen desert performance
Hello,<br>Could those of you who have operated LWB 300GDs and 280GEs in deserts please send some feedback as to how they do under those conditions?<p>I would imagine that the 300GD is quite a problem on terrain like sand rivers and dunes, but it would seem that the 280GE might do about as well as a Land Rover 110 with the 300Tdi (112HP, 195ft/lb torque@1800 rpm)..<p>Any comments, feedback, or real world experience appreciated.<p>--Jim Laurel<br>Seattle, WA<br><br><p>
Old 11-14-2001, 04:04 PM   #2 (permalink)
frank
Posts: n/a
Re: G-Wagen desert performance
Hi Jim,<p>I have been to the Sahara desert with my 300GD (SWB) a number of times, travelling right across the dunes for seven to ten days with a payload of about 1600 pounds.<p>On my first trip, the original 5-speed GETRAG gearbox was still fitted, which I found completely inadequate for the heavy terrain due to its very long first and second gear. Nevertheless the G performed relatively well - to the surprise of everyone in the group (including myself). <p>On return, we fitted a military gearbox and 8.25 R 16 tires in order to be better prepared for the next trip. Those modifications proved to be exactly the right choice - the G tackled even the highest of dunes in first high or second low and did not get stuck once. The engine, btw, is still the first one -with about 300k mls- and has maybe 75 or 80 of the original 88 bhp left in it.<p>What I found was, that far more important then horsepower are your driving technic and your tires. You avoid steering and keep the momentum goin´ - together with a set of tires that withstand low pressure well, even the 300 GD gets you everywhere. I suppose an automatic gearbox would make a difference again and is superior to a manual.<p>I would recommend, to keep the rear difflock engaged at all times while traversing dunes - in case you get into a critical situation where two wheels lift off the ground you can avoid a rollover by giving full throttle and countersteer.<p>Do avoid to open any of the filler caps for oil, brake fluid etc. while driving in the desert. Before you know it, that fine sand gets everywhere and could cause major damage.<p>Best of luck - frank<br> <p><br><br><p>
Old 11-14-2001, 09:59 PM   #3 (permalink)
Carlos V
Posts: n/a
Military gearbox?
Hi Frank<br>Is that military gearbox from a military G? Does it fit exactly to the engine and drive shaft? 5 speed too? Where did you find it?<br>It sounds interesting.<br>And about the tires, which pressure do you often use in the desert? on the original steel rims?<br>sorry for the ton of questions, but i'm interested in sand adventures. Thanks<p>Carlos<br><p>
Old 11-14-2001, 11:07 PM   #4 (permalink)
Jim Laurel
Posts: n/a
Re: Re: G-Wagen desert performance
Frank,<br>Thanks for the comments. I spent some time last December driving at the edge of the Sahara, near the Algerian border, in Wadi Rum in February, then in the Thar (Rajasthan) in April. This was part of a long overland trip I did with my family. We drove the whole route (40,000km over 11 months) in my 1997 Camel Discovery 300tdi without a single vehicle failure.<p>I'm trying to get an idea of how the 300GE and 300GD fare in the sand as compared to a known quantity, my Tdi Disco. I’ve compiled the numbers below to compare the 3 different vehicles I’m considering as an expedition vehicle for trips in the Americas.<p>I was surprised to note how heavy the Discovery is in comparison to the LWB G-Wagens, especially since the Discovery has a wheelbase of 100�, as opposed to the LWB W460, which I believe is around 112�. Where is all that weight coming from, especially since there should be a net savings due to the use of aluminum body panels? Mine must be quite a bit heavier still, since in full Camel trim, it includes a lot of extra equipment such as a full roll cage with integrated rack bolted to it through the roof, skid plates fore and aft, bull bar, winch, etc.<p>Anyway, looking at the numbers, it would seem that I should be able to expect more or less the same ( and probably a little better) dynamic performance from a 300GE LWB as the Discovery 300tdi.<p>The G Wagens sure are easier to come by than NAS 110s, and I'm sure are much better, ergonomically. Also, though I have never had a serious problem with any of my Rovers, I grew up with Mercedes cars and know how reliable and well-designed they are first hand.<p>Questions for you 300GE owners:<br>1) What kind of fuel economy are you seeing on your mixed city/highway loops?<p>2) How much range are you getting on a single tank?<p>3) Will the W460 300GE run on regular unleaded?<p>Regards to all,<br>--Jim Laurel<p>Here are the numbers...<p>300GD LWB<br>Power: 65kw @ 4400rpm<br>Torque: 172nm @ 2400rpm.<br>Kerb weight: 2055kg.<p>Discovery (300tdi)<br>Power: 83kw @ 4,000rpm<br>Torque: 265nm @ 1800rpm<br>Kerb weight: 2100kg<p>300GE LWB<br>Power: 115kw @ 5250rpm<br>Torque: 226nm @ 4250rpm<br>Kerb Weight: 2065kg<p>NAS Defender 110<br>Power: 134kw @ 4750rpm<br>Torque: 308nm @ 3250rpm<br>Kerb Weight: 2200kg<p><br>So, <br>: I have been to the Sahara desert with my 300GD (SWB) a number of times, travelling right across the dunes for seven to ten days with a payload of about 1600 pounds.<p>: On my first trip, the original 5-speed GETRAG gearbox was still fitted, which I found completely inadequate for the heavy terrain due to its very long first and second gear. Nevertheless the G performed relatively well - to the surprise of everyone in the group (including myself). <p>: On return, we fitted a military gearbox and 8.25 R 16 tires in order to be better prepared for the next trip. Those modifications proved to be exactly the right choice - the G tackled even the highest of dunes in first high or second low and did not get stuck once. The engine, btw, is still the first one -with about 300k mls- and has maybe 75 or 80 of the original 88 bhp left in it.<p>: What I found was, that far more important then horsepower are your driving technic and your tires. You avoid steering and keep the momentum goin´ - together with a set of tires that withstand low pressure well, even the 300 GD gets you everywhere. I suppose an automatic gearbox would make a difference again and is superior to a manual.<p>: I would recommend, to keep the rear difflock engaged at all times while traversing dunes - in case you get into a critical situation where two wheels lift off the ground you can avoid a rollover by giving full throttle and countersteer.<p>: Do avoid to open any of the filler caps for oil, brake fluid etc. while driving in the desert. Before you know it, that fine sand gets everywhere and could cause major damage.<p>: Best of luck - frank<br>: <p><br><br><p>
Old 11-14-2001, 11:37 PM   #5 (permalink)
frank.be
Posts: n/a
Re: Military gearbox?
<center><img src="http://www.mb-g.de/gdaten/datenbilder/getriebe_1.jpg"></center><p>Hello Carlos,<p>If you want to know more about this gearbox, please have a look at http://www.mb-g.de under 'datenbank', 'getriebe-umbau bei OM617 4-gang nach 5-gang 711.616'<p>http://www.mb-g.de/gdaten/thread.php?id=6<p>You will need a shorter drive-shaft, which, unfortunately, is very expensive. In fact, I paid as much for the gearbox as for the shaft.<br>This gearbox that I'm fitting was originated from a Unimog model. It was only used for testing in the Graz factory. I believe I was very lucky to find one...<p><br>@Frank, Have you moved to Ireland again? Many G-reetings<p>Greetings from Belgium, Frank.<p>: Hi Frank<br>: Is that military gearbox from a military G? Does it fit exactly to the engine and drive shaft? 5 speed too? Where did you find it?<br>: It sounds interesting.<br>: And about the tires, which pressure do you often use in the desert? on the original steel rims?<br>: sorry for the ton of questions, but i'm interested in sand adventures. Thanks<p>: Carlos<p><br><ul><li><a href="http://www.mb-g.de/gdaten/thread.php?id=6">711.116 gearbox</a></ul><p>
Old 11-15-2001, 01:07 AM   #6 (permalink)
frank
Posts: n/a
: Hi Frank<br>: Is that military gearbox from a military G? Does it fit exactly to the engine and drive shaft? 5 speed too? Where did you find it?<p>It is from the military G, the Wolf. You´ll find almost the same gearbox in T 1 vans 207-410. Beware though - those ones do not have the same "wading ability". 5 speed with 6,17 in first and 1,0 in fifth. Bolts straight to the engine (with the right clutch and pressure plate) but the driveshaft needs to be shortened. No need to buy an expensive new one as frank.be did.<p>: It sounds interesting.<br>: And about the tires, which pressure do you often use in the desert? on the original steel rims?<p>Typically 1,2 - 1,5 bar but you could go as low as 0,8<br>with decent tires (tubelees of course) on the original steel rims 5,5 or 6". frank<p>: sorry for the ton of questions, but i'm interested in sand adventures. Thanks<p>: Carlos<p><br><p>
Old 11-15-2001, 01:19 AM   #7 (permalink)
frank
Posts: n/a
Tire pressure
Hi again,<p>you are probably working in PSI, sorry. Here are the appropriate figures: 17 - 21 and 11,5 respectively.<p>frank<br>: : And about the tires, which pressure do you often use in the desert? on the original steel rims?<p>: Typically 1,2 - 1,5 bar but you could go as low as 0,8<br>: with decent tires (tubelees of course) on the original steel rims 5,5 or 6". frank<p><br><p>
Old 11-15-2001, 05:01 AM   #8 (permalink)
Gerald A
Posts: n/a
Re: Re: Military gearbox?
What is a T1 van?<p><br>: : Hi Frank<br>: : Is that military gearbox from a military G? Does it fit exactly to the engine and drive shaft? 5 speed too? Where did you find it?<p>: It is from the military G, the Wolf. You´ll find almost the same gearbox in T 1 vans 207-410. Beware though - those ones do not have the same "wading ability". 5 speed with 6,17 in first and 1,0 in fifth. Bolts straight to the engine (with the right clutch and pressure plate) but the driveshaft needs to be shortened. No need to buy an expensive new one as frank.be did.<p>: : It sounds interesting.<br>: : And about the tires, which pressure do you often use in the desert? on the original steel rims?<p>: Typically 1,2 - 1,5 bar but you could go as low as 0,8<br>: with decent tires (tubelees of course) on the original steel rims 5,5 or 6". frank<p>: : sorry for the ton of questions, but i'm interested in sand adventures. Thanks<p>: : Carlos<p><br><p>
Old 11-15-2001, 07:54 AM   #9 (permalink)
Ken C
Posts: n/a
You've got the wrong GWagen weight
My figures for my LWB W460 G is ~5,600+ lbs, or about 2,550 Kg. Put in fuel and supplies and occupants, and you're easily over 6,000 lbs or 2,700 Kg.<br><br><p>
Old 11-15-2001, 08:01 AM   #10 (permalink)
frank
Posts: n/a
T 1 van
: What is a T1 van?<p>Models 207,208,209,210,307,308,309,310,407,408,409,410 as being built from 1977 - 1995 - frank<p>: <br>: : : Hi Frank<br>: : : Is that military gearbox from a military G? Does it fit exactly to the engine and drive shaft? 5 speed too? Where did you find it?<p>: : It is from the military G, the Wolf. You´ll find almost the same gearbox in T 1 vans 207-410. Beware though - those ones do not have the same "wading ability". 5 speed with 6,17 in first and 1,0 in fifth. Bolts straight to the engine (with the right clutch and pressure plate) but the driveshaft needs to be shortened. No need to buy an expensive new one as frank.be did.<p>: : : It sounds interesting.<br>: : : And about the tires, which pressure do you often use in the desert? on the original steel rims?<p>: : Typically 1,2 - 1,5 bar but you could go as low as 0,8<br>: : with decent tires (tubelees of course) on the original steel rims 5,5 or 6". frank<p>: : : sorry for the ton of questions, but i'm interested in sand adventures. Thanks<p>: : : Carlos<p><br><p>
